Installation of RetroPie on Raspbian fails: es_system.cfg stays empty.
Hi, I had RetroPie running on my Raspberry Pi 2 and everything worked fine, until I tried to update my retro pie installation using the RetroPie-Setup Script.
This is my system,
cat /etc/*release*
gives me:PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)" NAME="Raspbian GNU/Linux" VERSION_ID="8" VERSION="8 (jessie)" ID=raspbian ID_LIKE=debian
I tried to uninstall and then reinstall retropie with
sudo ./retropie_setup.sh
. I’m using the latest version of the git repository (Version 4.0.6 2477bdb)This is the error I get, when trying to install (see last few lines of the snippet):
= = = = = = = = = = = = = = = = = = = = = Installing 'retropiemenu' : RetroPie configuration menu for EmulationStation = = = = = = = = = = = = = = = = = = = = = „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/gamelist.xml“ -> „/home/pi/.emulationstation/gamelists/retropie/gamelist.xml“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons“ -> „/home/pi/RetroPie/retropiemenu/icons“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/audiosettings.png“ -> „/home/pi/RetroPie/retropiemenu/icons/audiosettings.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/bluetooth.png“ -> „/home/pi/RetroPie/retropiemenu/icons/bluetooth.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/configedit.png“ -> „/home/pi/RetroPie/retropiemenu/icons/configedit.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/esthemes.png“ -> „/home/pi/RetroPie/retropiemenu/icons/esthemes.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/filemanager.png“ -> „/home/pi/RetroPie/retropiemenu/icons/filemanager.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/raspiconfig.png“ -> „/home/pi/RetroPie/retropiemenu/icons/raspiconfig.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/retroarch.png“ -> „/home/pi/RetroPie/retropiemenu/icons/retroarch.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/retronetplay.png“ -> „/home/pi/RetroPie/retropiemenu/icons/retronetplay.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/rpsetup.png“ -> „/home/pi/RetroPie/retropiemenu/icons/rpsetup.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/runcommand.png“ -> „/home/pi/RetroPie/retropiemenu/icons/runcommand.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/showip.png“ -> „/home/pi/RetroPie/retropiemenu/icons/showip.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/splashscreen.png“ -> „/home/pi/RetroPie/retropiemenu/icons/splashscreen.png“ „/home/pi/git/RetroPie-Setup/scriptmodules/supplementary/retropiemenu/icons/wifi.png“ -> „/home/pi/RetroPie/retropiemenu/icons/wifi.png“ /home/pi/git/RetroPie-Setup/scriptmodules/helpers.sh: Zeile 795: 3369 Speicherzugriffsfehler xmlstarlet sel -D -I -t -m "/" -e "systemList" -m "//system" -s A:T:U "$1" -c "." "/etc/emulationstation/es_systems.cfg.bak" > "/etc/emulationstation/es_systems.cfg" Unable to install binary for retropiemenu
Somehow the install-script can’t create the file
… it stays empty …xmlstarlet --version
gives me:compiled against libxml2 2.9.1, linked with 20901 compiled against libxslt 1.1.28, linked with 10128
So emulationstation won’t start complaining, that there’s no configuration.
Any suggestions?
Commenting the following lines out brings me one step further. The configuration file is now created. But emulationstation quits with a Segmentation fault now. I guess the problem is somewhere else not with the setup-script. I will dig further after I get some sleep.
Here the corresponding snippet in the file
and the lines I commented-out.## @fn sortESSystems() ## @param field field to sort by (eg name / platform etc) ## @brief Sorts `/etc/emulationstation/es_systems.cfg` system list by specified field. function sortESSystems() { local field="$1" cp "/etc/emulationstation/es_systems.cfg" "/etc/emulationstation/es_systems.cfg.bak" # xmlstarlet sel -D -I \ # -t -m "/" -e "systemList" \ # -m "//system" -s A:T:U "$1" -c "." \ # "/etc/emulationstation/es_systems.cfg.bak" >"/etc/emulationstation/es_systems.cfg" }
After some hours of sleep, I tried to reinstall RetroPie again.
During the installation progress I get the following error:debconf: Perl may be unconfigured (Illegal declaration of subroutine Hash::Util::unlock at /usr/lib/arm-linux-gnueabihf/perl/5.20/Hash/Util.pm line 79. Compilation failed in require at /usr/share/perl/5.20/fields.pm line 122. Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 10. Compilation failed in require at (eval 1) line 4. BEGIN failed--compilation aborted at (eval 1) line 4. ) -- aborting 0 aktualisiert, 44 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
So Perl might not be installed correctly… Will try to reinstall perl with
sudo apt-get install --reinstall perl
I’m not sure why my perl installation got broken, but I was not able to fix it. I ended up with a fresh Raspbian installation. Now everything works fine egain.
