    "Fix for Majora's Mask"?
    majoras mask
    2 Posts 1 Posters 1.0k Views
      Static_C
      It's listed in the changelog for 4.0.2. My question is: what does it fix exactly?
      I've never been able to get that game to run properly. Only rice plugin would render the frame buffer effects used in the game's cutscenes but then it wouldn't display the bomber notebook as well some of the other graphical effects like coronas from light sources. If I ran GlideN64 the game ran smoother and EVERYTHING worked except for the frame buffer effects. So is this the fix I've been waiting for?
        Static_C
        I'm sure someone must know??
