    Built Adafruit's PiGRRL2 - controls work in emulationstation, but not in any roms
    2 Posts 1 Posters 1.5k Views
      sellersmd
      The info:
      Pi Model: Pi 3
      RetroPie Version Used: 3.7
      Built From: SD Image from retropie.org.uk
      USB Devices connected: none
      Controller used: keyboard
      Error messages received: none
      Guide used: many
      File: /opt/retropie/configs/all/retroarch.cfg
      Emulator: all
      Attachment of config files:
      Long story short, I built Adafruit's PiGRRL2 using the guide at https://learn.adafruit.com/pigrrl-2/overview.
      All of the components are working properly, the PiTFT display works great, the buttons are mapped to keyboard buttons via the Adafruit-Retrogame package, etc.
      I can successfully launch emulationstation, and the on-board controls (mapped to keyboard keys) work perfectly. I went through all of the controller config in the start menu of emulationstation as well. I can navigate and launch roms successfully as well. However, when I launch a rom, none of the on-board controls work at all. Not a single button. Interestingly, if I launch a rom and them plug in a USB keyboard, the keyboard controls work properly, but the on-board controls do not.
      At this point, I am really just looking to have a single config file for all emulators.
      Here is my current config in /opt/retropie/configs/all/retropie.cfg: http://pastebin.com/RyZjLzh1
      Can anyone tell me why the controls work perfectly in emulationstation but will not work in any roms? I can also exit to terminal and the keys work for their representative keyboard characters there as well, so I assume the keyboard binding is working properly.
      Thanks in advance!
        sellersmd
        So I finally figured this out. Turns out I needed to add 'evdev' as a module in /etc/modules, and then everything is hunky dory.
        Here's where I finally found my solution: https://github.com/adafruit/Adafruit-Retrogame/issues/21
        Hopefully someone else will find this useful.
