    Best case for cooling a Pi 3?
    casecoolingpi3pi 3
    31 Posts 17 Posters 42.0k Views
    • H
      H-A-Z @H-A-Z
      @H-A-Z *may
      • edm203E
        edm203
        I have this wooden case, and it's terrible for keeping my pi cool.
        DecaPi Slider
        I bought a plastic case on ebay with a fan for about $6, and it's much better at keeping the temp down.
        Pi Model or other hardware: Pi3B
        Power Supply used: 2.5 amp power supply
        RetroPie Version Used: 4.2.10
        Built From: Premade from Retropie website
        USB Devices connected: 4x ibuffalo snes controllers
        • sergioadS
          sergioad
          An aluminium case enclosed in a flexible and breakable plastic shell to protect the internals
          • HurricaneFanH
            HurricaneFan
            I have this aluminum case, no complaints:
            https://flirc.tv/more/raspberry-pi-case
            • RionR
              Rion
              It's relatively easy to modify a case to do the same.
              You just need something to hold the heatsink in place.
              FBNeo rom filtering
              Mame2003 Arcade Bezels
              Fba Arcade Bezels
              Fba NeoGeo Bezels
              • RionR
                Rion
                Here are the results with a massive heatsink and a fan.
                Here are one more and final test with overclocking using a massive heatsink.
                This is by far the best results in have seen and that's using an Aluminum heatsink.
                FBNeo rom filtering
                Fba Arcade Bezels
                Fba NeoGeo Bezels
                  tekn0
                  This case works as a heatsync and keeps temps in check. https://nostalgiatechs.com/heatsync-case-pi-amazon
                  edm203E 1 Reply Last reply Reply Quote 0
                  • edm203E
                    edm203 @tekn0
                    @tekn0 That's a great case, but reviewers state it doesn't fit well for Pi 3.
                      tekn0 @edm203
                      @edm203 it fits mine fine, the only issue is that you need a paperclip to pull out the sd card. as it's flush with the metal. this case was a life saver for the price because my pi3 would overheat after about 5 mins of neogeo play, now it has no issues at all.
                      • N
                        nschloe
                        I've created stressberry to create standardized temperature signatures; hopefully we'll be able to properly compare all solutions with it. I'm hoping to be able to add a few more graphs in the coming weeks. Perhaps other people would like to run stressberry as well.
