    Command line command works but doesn't work if I put it into a script?
    autostart rombootnes
    6 Posts 4 Posters 2.9k Views
      kick53rv3
      I am trying to get my retropie to auto load a rom on start without going into emulation station.
      I tested the following command in command line and it launches the game successfully:
      /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ nes /home/pi/Retropie/roms/nes/mario.nes
      but when I put it into /opt/retropie/configs/all/autostart.sh (only the above line, nothing else in the file), on boot up it tries to load the game then falls back into command line.
      I also tried to put the line above in a .sh script, gave +x permission, it would show the loading game screen (like the startup) but falls back directly to command line.
      Do I need to do something different to put the command into a script?
      Thanks!
      • markyh444M
        markyh444 @kick53rv3
        @kick53rv3 is the Retropie part of the ROM path not meant to be RetroPie? Looks like it from the Wiki on transferring ROMs
        Retropie in a PSX - Pi3
          BuZz administrators
          You already have another topic open too.
            kick53rv3
            @BuZz sorry I was not the OP in the other thread
            @markyh444 ill double check it but the same command works in command line but when I put it into a script and run the script it doesn't work
              meleu @kick53rv3
              @kick53rv3 as @markyh444 said, Linux is case sensitive, so it won't find /home/pi/Retropie/roms/nes/mario.nes (as you typed on the first post).
              If it isn't the problem, to let us help you, you should post the exact error message you got when it "tries to load the game then falls back into command line".
                BuZz administrators
                Sorry. My mistake. This is why it's confusing when people add to other posts. I believe it's the case issue as @meleu has said.
