    Problem with Hatari & lr-hatari
    hatari
    8 Posts 2 Posters 3.8k Views
    • V
      vfrvulcan
      Have just built a new card with RetroPie 4.1 and latest updates but can't get hatari (Atari ST) to work.
      Select a program in ES and hatari returns
      Parameters:
      Executing: /opt/retropie/emulators/hatari/bin/hatari --confirm-quit 0 --statusbar 0 --zoom 1 -w --compatible 1 --timer-d 0 --borders 1 "/home/pi/RetroPie/roms/atarist/Dungeon Master (1987)(FTL)(fr)[b].st"
      /opt/retropie/emulators/hatari/bin/hatari: error while loading shared libraries: libcapsimage.so.5: cannot open shared object file: No such file or directory
      in /dev/shm/runcommand.log
      Changing the default launcher to lr-hatari produces the following in /dev/shr/runcommand.log
      Parameters:
      Executing: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/Frontier - Elite II (1993)(Gametek - Konami).st" --appendconfig /dev/shm/retroarch.cfg
      [libretro-test]: Got size: 640 x 480.
      Hatari v1.8.0, compiled on:  Dec  2 2016, 17:53:35
      IPF : IPF_Init
      IPF : capsimage library version release=5 revision=1
      Configured max Hatari resolution = 640x480, optimal for ST = 832x588
      Inserted disk '/home/pi/RetroPie/roms/atarist/Frontier - Elite II (1993)(Gametek - Konami).st' to drive A:.
      NVRAM not found at '/home/pi/.hatari/hatari.nvram'
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 933:  9735
      Bus error LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/Frontier - Elite II (1993)(Gametek - Konami).st" --appendconfig /dev/shm/retroarch.cfg
      For lr-hatari, tos.img has been moved into the /opt/retropie/emulators/retroarch/bin folder (it complained about it not being there before.
      Any pointers to get it to work would be appreciated.
      Have uninstalled and re-installed using both source and binary but the problem persists.
      Aaron
        BuZz administrators
        lr-hatari has problems - I don't recommend using that currently - I will fix up the issue with hatari (missing library).
          BuZz administrators @vfrvulcan
          @vfrvulcan Note when reporting problems please provide more details - eg I don't know which system you are running on - also please put logs in "code" blocks. See https://retropie.org.uk/forum/topic/3/read-this-first which you have to agree to read on registration and which is in bold at the top of the screen.
          I will format your post.
          • V
            vfrvulcan
            Thanks for the quick reply BuZz,
            Apologies for forgetting to mention Pi3, connected USB devices, filename, controller used seemed immaterial to the problem.
            Couldn't see/still can't see how to put "code " blocks when creating a comment - all I see is bold/italic/list item/strikethrough/link/picture/zen mode/upload image. Nothing about code blocks so apologies again if I've missed that somewhere - I was looking for something like that before I posted.
              BuZz administrators
              You sure you read https://retropie.org.uk/forum/topic/3/read-this-first ?
              it states
              Use markdown to format your posts - see http://commonmark.org/help/ - and put large logs on a pastebin type site like http://paste.ubuntu.com/ http://pastebin.com/ or similar.
              Also when writing a post there is a compose? link at the top right which links off to the site with the markdown details.
              If you are asking for help it's best to let us to decide what information is needed and what isn't. Emulator issues can easily be platform specific.
              • V
                vfrvulcan
                Yes, but a victim of speed-reading, I saw the bit about pastebin for large logs but not the formatting. Apologies once again
                  BuZz administrators
                  hatari should work now if you update from binary
                  • V
                    vfrvulcan
                    Indeed it does, many thanks for the quick fix
