    (noob question) Sound on ES Theme SImple Dark
    5 Posts 2 Posters 2.3k Views
    • OrnitorickO
      Ornitorick
      There is any way to put sound on simple dark when change roms like on the theme carbon ?
      Or is my pi that is with problem?
      i Know this silly question :(
      • W
        wetriner
        You're right, there's no sound with es-simple-dark, but that's not an accident. You can make some custom edits if you'd like. Compare carbon.xml:
        		<textlist name="gamelist">
        			<selectorColor>1c1c1c</selectorColor>
        			<selectedColor>8b0000</selectedColor>
        			<primaryColor>969696</primaryColor>
        			<secondaryColor>7a6161</secondaryColor>
        			<fontPath>./art/Cabin-Bold.ttf</fontPath>
        			<forceUppercase>1</forceUppercase>
        			<scrollSound>./art/select.wav</scrollSound>
        		</textlist>
        To simple-dark.xml
        			<selectorColor>151515</selectorColor>
        			<selectedColor>0098a6</selectedColor>
        			<primaryColor>ebebeb</primaryColor>
        			<secondaryColor>ebebeb</secondaryColor>
        			<fontPath>./art/Roboto-Regular.ttf</fontPath>
        			<fontSize>0.03</fontSize>
        		</textlist>
        Just note you'll have to copy over the sound file to the simple-dark art folder, or type the full path to just look in carbon's art folder.
        Theme files are found in /etc/emulationstation/themes
        OrnitorickO 2 Replies Last reply Reply Quote 0
        • OrnitorickO
          Ornitorick @wetriner
          @wetriner Nice, i'll try some stuff here and come back to post!
          Thank you for the great answer
          • OrnitorickO
            @wetriner Yeh i have copyed the "Select.wav" to "/etc/emulationstation/themes/simple-dark/art"
            And incremented the line <scrollSound>./art/select.wav</scrollSound> on /etc/emulationstation/themes/simple-dark/simple-dark.xml
            Wokrs perfect :)
            By the way, how can i commented the program lines like you did on the forum?
            Thank you.
            • W
              wetriner
              If you want to learn more markdown, there are probably some good guides available online with the syntax. I only really know enough to get by. For the code you can either start each line with four spaces or you can use three backticks(`) to start and end the block.
