    Help with MAME
    mame-mame4all
    2 Posts 2 Posters 908 Views
      kajih
      having issues trying to get my roms to load.
      the main one i'm trying to play is "Capcom vs. SNK 2 Millionair fighting 2001 REV A GDL-0007A am i using the wrong file that isn't compatible?
      mame will show up and the games are on the list. however, when i try to run it it will go to the using boot up screen of press A to go to setup options then go black for a few seconds and back to the MAME game list.
      I have the neogeo.zip bios installed in the rom folder MAME4ALL
      • rbakerR
        rbaker @kajih
        @kajih You have to be joking right? You are not seriously asking this?
        In bold at the top of this page:
        You need to read the very clear guidance provided on MAME. Your post has been replicated hundreds of times and answered hundreds of times. A search on here would reveal hundreds of threads on this topic. Just by typing in MAME HELP into the search bar will reveal them.
        But more importantly, it would reveal this:
        https://retropie.org.uk/forum/topic/2859/how-to-use-mame-with-retropie-help-guide
        This answers everything.
        You should also read these after the above as it will reinforce the above:
        https://github.com/retropie/retropie-setup/wiki/MAME
        https://github.com/retropie/retropie-setup/wiki/Managing-ROMs
