    Scraper help running roms from USB stick
    scraper retropi
    1 Posts 1 Posters 824 Views
      chuzzwuzzer
      Hi. Total newb to this. Have setup my Rpi3 running Retropie 4.1 with my roms stored on a 64gb USB stick. Everything running fine following these instructions: https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive but I'm struggling with selphs scraper. It took about 10 mins to scrape all the roms but as they are on the usb stick I'm not seeing anything. Found this link :' If your roms are located on another source then the default one you can download the stand alone releases. sselph's scraper releases Please refer to Sselphs Scraper Advanced Configuration when using this method. ' But I'm a bit lost now. Is it just a case of changing the path somehow?
      Cheers.
