    Retropie 4.1 Vice Emulator C64 Disk Drive problem
    vice drivetrue emulation
    3 Posts 2 Posters 2.5k Views
      Marcone698
      Hi all,
      I have a Raspberry Pi Zero
      Retropie 4.1
      Latest Vice emulator
      Sandisk Ultra Imaging Micro SDHC I 32GB Class (10)
      The C64 emulator vice works well but i I uncheck "Drive true emulation" when i try to load something i got "Drive not present error", if I check a new one "Drive true emulation" all works good.
      If I use vice under windows i don't ave this problem.
      Unfortunately with drive true emulation is very slow.
      Thanks for support
      Marco
      • W
        windale @Marcone698
        @Marcone698 Enable 'Virtual Device Traps' option (under the True Drive Emu option) and it will now work. That option should be on by default but whoever made the default Retropie custom config didn't enable it.
          Marcone698
          @windale Hi, thanks a lot, works perfect!
