    Wipeout 2097 PSX No Sound
    6 Posts 4 Posters 7.7k Views
    • CharcoC
      Charco
      For some reason there is no music in Wipeout 2097 on the lr-pcsx-rearmed core. I've had a search online and see that this issue crops up on multiple emulators. Does anyone know if there is a way to fix this as the soundtrack is one of the highlights of this game. I have the game in bin + cue format on RetroPie 3.7.
      • W
        wetriner
        Try launching from the cue and not the bin, since it's in charge of the soundtrack.
        CharcoC 1 Reply Last reply Reply Quote 0
        • FloobF
          Floob
          You need to make sure your audio files are merged in your .bin and the cue file points to all the right tracks.
          This link helps with that:
          http://www.epforums.org/showthread.php?57757-ECM-And-APE-Guide
          This should also help:
          • CharcoC
            Charco @wetriner
            @wetriner Yeah I am launching from the cue file as I have all my bin files hidden after editing my es_systems.cfg. @Floob how do I check the files inside the bin file?
            • cafarellidigitalC
              cafarellidigital
              Below is what my CUE file looks like. I only have one BIN file that the CUE file points to, which means all of the audio tracks are contained within that one BIN. The CUE file tells the emulator where to look to start a track. "Track 01" is the game data, whereas the other tracks are the music. This is for Wipeout XL (the North American name for Wipeout 2097). If you have your BIN named differently, you'll need to name it accordingly in the CUE file.
              FILE "Wipeout XL.bin" BINARY
                TRACK 01 MODE2/2352
                  INDEX 01 00:00:00
                TRACK 02 AUDIO
                  PREGAP 00:02:00
                  INDEX 01 08:07:59
                TRACK 03 AUDIO
                  INDEX 00 13:58:59
                  INDEX 01 14:00:59
                TRACK 04 AUDIO
                  INDEX 00 18:28:50
                  INDEX 01 18:30:50
                TRACK 05 AUDIO
                  INDEX 00 24:02:12
                  INDEX 01 24:04:12
                TRACK 06 AUDIO
                  INDEX 00 29:23:61
                  INDEX 01 29:25:61
                TRACK 07 AUDIO
                  INDEX 00 35:31:09
                  INDEX 01 35:33:09
                TRACK 08 AUDIO
                  INDEX 00 40:12:61
                  INDEX 01 40:14:61
                TRACK 09 AUDIO
                  INDEX 00 45:03:41
                  INDEX 01 45:05:41
                TRACK 10 AUDIO
                  INDEX 00 51:11:64
                  INDEX 01 51:13:64
                TRACK 11 AUDIO
                  INDEX 00 55:53:16
                  INDEX 01 55:55:16
                TRACK 12 AUDIO
                  INDEX 00 62:07:66
                  INDEX 01 62:09:66
              Console Stripe Video Splashscreen | Mushberry Splatter Splashscreen
              • CharcoC
                Charco
                I got it working with another bin + cue :)
