    Speed of Vice
    vicespeedraspberry pi 1
    2 Posts 2 Posters 1.3k Views
      sancho1234
      I have a Raspberry Pi v1, and I would like to use the Vice emulator with RetroPie. But it's working on 37% with 1 fps only. It's terrible... In the past, I've tried a different OS system, and run much faster. What is the problem? Can you help me in these case? Thank you for your help!
        BuZz administrators @sancho1234
        @sancho1234 You will need to overclock. Also make sure sid emulation is set to "fast mode" and not accurate. You may want to consider a rpi3 though for c64 emulation (if you want accuracy etc).
        Please read the link at the top of the screen - as I have no idea what version of RetroPie you are running for example (and no idea of what version of vice).
