    Mouse pointer showing up in top left hand corner of daphne emulator
    mouse pointer
    4 Posts 3 Posters 981 Views
      rablack97
      Pi Model: Pi3 Model B
      RetroPie Version Used: latest
      USB Devices connected: wireless keyboard
      Controller used: xbox 360 wired
      Error messages received: non
      Emulator: Daphne
      How to replicate the problem: run the game
      I've seen a thread where this happened to a user, anybody familiar with the fix to disable the mouse pointer
        rablack97
        Figured it out, -fullscreen was needed as a parameter in the command file.
        T 1 Reply Last reply Reply Quote 1
          therexershow @rablack97
          @rablack97 if you’re still around , what does that mean needed fullscreen in command line? I run Retropie on Ubuntu and it shows up in upper left too.
            mitu Global Moderator @therexershow
            @therexershow You're replying to a 3 years old topic - if you have a specific problem please open a new topic instead and add the info asked inhttps://retropie.org.uk/forum/topic/3/read-this-first.
