    ScummVM lag with joystick control
    45 Posts 16 Posters 22.3k Views
      dudleydes @Dominus
      @Dominus Yes, you should be. I copied the binary using the sudo cp command. There was no installation as such.
      I did have an issues with the GUI themes. The Modern (orange and yellow) theme wasn't working, just the Classic (green and black) one. This is easy to fix if you run into the same issue.
      Download the Modern theme, scummmodern.zip, from the ScummVM github page. Note that this is for version 1.7.0. If you are using a different version, then make sure you choose the appropriate branch.
      Transfer the zip file to your pi. Launch ScummVM from ES and select Options. In the Paths tab, you can choose the Theme Path (the location of scummmodern.zip) and in the Misc tab, you can choose your theme by pressing the Theme button.
      DominusD 1 Reply Last reply Reply Quote 0
      • DominusD
        Dominus
        So I should just be able to copy /opt/retropie/emulators/scummvm/bin/scummvm from an old install and replace it on my current one?
        • DominusD
          Dominus @dudleydes
          @dudleydes Hmm I tried my above method but it didn't work. Where do I find the binary? or is there more files to copy over?
            dudleydes @Dominus
            @Dominus Strange. I copied the ScummVM binary from the location you mentioned on a previous build to the home directory on the latest build. Then I ran the following command to copy the binary to the correct location:
            sudo cp scummvm /opt/retropie/emulators/scummvm/bin/scummvm
            That was it. I ran the +Start ScummVM script and version 1.7.0 launched without issue except for the classic GUI theme being used as outlined above.
            • DominusD
              Dominus
              @herb_fargus Has this been fixed with the 4.1 release? How do I just copy an older version of ScummVM over to a new version of RetroPie?
              • DominusD
                Dominus
                Any help with this yet? :-(
                  darkav
                  I have the same problem. Any news on this?
                  • DominusD
                    Dominus
                    What I did was took all the scummvm folders I could find in an older version. (I think it was the 3.7 image?) Just WinSCP over and copy all of the /opt/retropie/emulators/scummvm files. Save to your desktop and then load up your newest image and replace the files. Pretty sure this will work. I thought there might have been another folder to copy, but I don't think that one mattered. Let me know if it works for you. I just made a new image, so when I have time I'll have to do it again anyway.
                      darkav @Dominus
                      @Dominus Tested with the one in Retropie v3.7 => ScummVM 1.8.1pre
                      Same issue.
                      Now i will try with an older version...
                        darkav
                        OK, with SCUMMVM 1.7.0 works. Can be taken from Retropie v3.6.
                        • DominusD
                          Dominus @darkav
                          @darkav Ok good to know! Maybe eventually they'll just scrap the updated Scumm and go back to the older version? or just fix the problem in future versions.
                            BuZz administrators @Dominus
                            @Dominus We don't maintain/develop every piece of software we include with RetroPie - the joystick control issue has happened since we are building scummvm on SDL2. Not sure if they still include SDL1 support, but the issue needs to be fixed either at the scummvm project or via SDL2.
                            It has been brought up here - http://forums.scummvm.org/viewtopic.php?p=83050
                            i may consider including an older scummvm at some point, but you can probably work around it by using xboxdrv or by using a wireless keyboard with mouse/pad etc.
                            mediamogulM DominusD 2 Replies Last reply Reply Quote 0
                              mediamogul Global Moderator @BuZz
                              @BuZz
                              Can we take this to mean that the older version would be considered as an alternative installation? I would hate to lose the current and future advancements this software has to offer in favor of alleviating this one issue.
                                BuZz administrators @mediamogul
                                @mediamogul yeah - it wouldn't be default or anything.
                                  @BuZz
                                  Ah, fantastic!
                                  @Dominus, @darkav
                                  I'm sure that you've both read above about the ability to use xboxdrv to solve this issue. I do recognize that the learning curve for the utility is high and that it's not even always an option. Once I get some spare time to sit down with it, I plan on revising the guide with a simpler approach to it's use that may appeal to more people. However, if you're interested, an example and work-through of this new approach can be found here in the mean time.
                                    darkav
                                    @mediamogul Tnx, I'll try xboxdrv. but I'm using ControlBlock for Controllers and I'm not sure it can be used with it. I will investigate.
                                    • DominusD
                                      Dominus @BuZz
                                      @BuZz Oh yeah I know. I just meant putting the older version back in. Not really sure what you don't get with the new updates, but as long as the games work....
                                      herb_fargusH mediamogulM 2 Replies Last reply Reply Quote 0
                                      • herb_fargusH
                                        herb_fargus administrators @Dominus
                                        @Dominus myst support is one thing...
                                          mediamogul Global Moderator @Dominus
                                          @Dominus
                                          'Myst' was indeed a biggie and they are constantly adding support for more games all the time. I've personally played though two Sherlock Holmes games that weren't playable before version 1.8.
                                            Chris
                                            I had experienced the same issue that most people here already mentioned.
                                            I uninstalled the package "scummvm" and installed "scummvm-sdl1" instead. With the sdl1-version the joystick works fine.
                                            DominusD RookervikR 2 Replies Last reply Reply Quote 0
