    retroarch.cfg not being read?
    6 Posts 3 Posters 1.8k Views
      kruuth
      I've checked the file in /opt/retropie/configs/all and it is globally writable but whenever I try to make a change inside of retroarch and save it doesn't take. Is there something that I need to do in order to get this to save? Is it saving to a different place?
      • FloobF
        Floob
        If you are making the change in RGUI itself you may want to check this guide:
        If you change in RGUI it will write a file to /opt/retropie/configs/{systemname}/ (and it wont be read automatically for good reasons.
        You can of course edit the global retroarch.cfg directly if you want.
          kruuth
          I was trying to get the global settings changed, in this case, pulling up the menu, exit buttons, etc.
          • herb_fargusH
            herb_fargus administrators @kruuth
            @kruuth you can use the configuration editor:
            https://github.com/RetroPie/RetroPie-Setup/wiki/Configuration-Editor
              kruuth
              Thank you. I didn't see how to configure keyboard inputs on there but I'll look again. I think I missed it.
              FloobF 1 Reply Last reply Reply Quote 0
              • FloobF
                Floob @kruuth
                @kruuth
                When in the config menu, try
                • Setup / Configuration
                • Edit RetroPie/Retroarch configurations
                • Advanced Configuration
                • Manually edit Retroarch configurations
                • /all/retroarch.cfg
