    PS4 Controller + Pi3 + RetroPie 3.7 + Bluetooth Dongle SOLVED
    9 Posts 5 Posters 9.0k Views
    • F
      FreakyBigFoot
      Has anyone been able to successfully get this work yet? I have tried following a couple guides but they seem to be for RetroPie 2.3 and back.
      I can see the controller and pair it and connect it. It shows up as 'Wireless Controller'. I just can't configure it.
      Yes I know the pi3 has Bluetooth built in. It causes the pi3 to freeze.
        BuZz administrators
        Moved to Support area. The games category is not for configuration help.
        • F
          FreakyBigFoot
          This post is deleted!
          • F
            FreakyBigFoot
            I figured it out! I even wrote a wiki!
            wiki.freakybigfoot.com
            • RionR
              Rion @FreakyBigFoot
              @FreakyBigFoot said in PS4 Controller + Pi3 + RetroPie 3.7 + Bluetooth Dongle SOLVED:
              Can you add your findings to the Retropie wiki?
              FBNeo rom filtering
              Mame2003 Arcade Bezels
              Fba Arcade Bezels
              Fba NeoGeo Bezels
              • F
                FreakyBigFoot
                Sure.
                Here you go.
                herb_fargusH 1 Reply Last reply Reply Quote 1
                • herb_fargusH
                  herb_fargus administrators @FreakyBigFoot
                  @FreakyBigFoot Mind if we change the title to Setting up a PS4 controller just to fit with the conventions of the other controller wiki pages and then we can add it to the sidebar on the right under ps3 controller
                  • F
                    FreakyBigFoot
                    Sure. Whatever you think will help.
                      jetro
                      Hi, I'ven been playing around with connecting a ps4 to retropie. The wike from FreakyBigFoot was a very big help. Like it sad, i borrowed 2 controllers from my friend, one newer , so i needed to use the ds4drv.
                      Today i bought my own new controllers, wich turned out to be the new version 2 (light bar on top of the touchpad and grey buttons).
                      I disabled ds4drv on startup in rc.local, connected both in the bluetooth menu, and they worked fine! buttons get registered.
                      (with the ds4drv i couldn't connect the second one)
                      Maybe someone else can confirm this. I just tought to share this so someone could put it in the wikki to help other people.
                      Thx for all the help, especially FreakyBigFoot
                      ps i also did the firmware upgrade discribed on the wikki of FreakyBigFoot , maybe it matters
