    Raspberry PI 3 and 3.5" LCD
    lcdscreen3.5 spi
    6 Posts 3 Posters 4.5k Views
      Marcone698
      Hi all,
      i have bought a Raspbery Pi 3 with this configuration :
      retropie-4.1-rpi2_rpi3.img
      32 GB SD Card
      and 3.5 LCD 320x480 QDM480SPITP9486RB
      The LCD Driver : LCD-show-161112.tar.gz
      downloaded here :
      http://www.spotpear.com/learn/EN/raspberry-pi/Raspberry-Pi-LCD/Drive-the-LCD.html
      when i boot I can see the terminal in LCD but when emulation station start i have a black screen, if I plug the hdmi cable i can see terminal while booting in LCD and TV but Emulation station only in TV.
      Is there something to change in retropie?
      Thanks a lot
        Jae Sang LEE @Marcone698
        This post is deleted!
          @Marcone698
          @Marcone698
          Hi ~
          you can are reference my old post about tft-lcd project.
          • first reference post
          • [two reference post]http://www.rasplay.org/?p=7554)
          you can sovle bottom command follow.
          1. fbcp build
          $ sudo apt-get install cmake
          $ git clone https://github.com/tasanakorn/rpi-fbcp
          $ cd rpi-fbcp/
          $ mkdir build
          $ cd build/
          $ cmake ..
          $ make
          $ sudo install fbcp /usr/local/bin/fbcp
          2. fbcp and run
          adove all working after pre run fbcp.
          $ fbcp &
          and final retropie emustation run.
          M K 2 Replies Last reply Reply Quote 0
            Marcone698 @Jae Sang LEE
            @Jae-Sang-LEE
            Hi Jae,
            works perfectly!
            Thanks a lot
              @Marcone698 Thank-you
              and auto run post can is [here] reference.(http://forums.rasplay.org/topic/159/사용팁-tft-lcd-설정-과-자동실행-서비스-등록하기/2)
                krullbeast @Jae Sang LEE
                @Jae-Sang-LEE hello, and thank you for your help. how do i save it to work on startup? when i type "fbcp &" and press enter, it works! but when i reboot my pi3b, it goes back to the black screen. i know this post is old, just thought you might see it, thank you for any advice in advance and have a great day today!
