    WiiU wireless not connecting
    2 Posts 1 Posters 737 Views
      shift838
      I can get the WiiU Professional wireless bluetooth controller to connect to the RetroPie via command line but if it disconnects and i power the controller back up it does not connect. Also it does not connect when booted. I have to issue the command lines to connect it every time.
      should it connect automatically since it has been paired and trusted?
        shift838
        i redid the connection via the retropie bluetooth gui and now it stays connected.
        But....
        I put in a second controller and RetroPie sees both of them and both are connected (but both have the led light as player 1 controller). I can control the EmulationStation with either controller, but when i go into a game like Galaga or Phoenix within MAME both players have to use the same controller. Is there a way to have one set as one player and the other as 2 player?
