    Top requested arcade games for overlays
    overlayarcadepoll
    594 Posts 34 Posters 724.8k Views
      UDb23 @quicksilver
      @quicksilver said in Top requested arcade games for overlays:
      I would be very interested in overlays for space fury and star castle.
      Star Castle created and available in the Repo:
      Note: had no time to actually test it.
      quicksilverQ 1 Reply Last reply Reply Quote 3
      • RiverstormR
        Riverstorm
        @UDb23 - Thanks for the new overlay.
        You're spot on. The wind is the wild card killer for sure. Cold with no wind is still pretty cold and causes frost bite quickly but once you add wind in the mix it becomes a killer that strips heat from the body pretty fast and stings.
        The house made a lot of "popping" noises as things expanded. Concrete and driveways up-heave a few inches. Chimney's are caked in ice due to warn moist air hitting extreme cold. Windows freeze with ice on the inside. Where the air meets the window glass it (the air) can't hold as much moisture so it "drops" water droplets on the window and overnight you get pretty thick ice. Tire pressure lowers with cold so sensors are tripped for low tire pressure. That kind of cold just eats batteries. I always buy the biggest cold cramping amp battery I can get a hold of for my car. We also fight a little with freezing rain so in this area we pull up your windshield wipers so they are up off the windshield, like you're cleaning the windshield, and then leave them that way at work. No one usually messes with them.
          UDb23 @Riverstorm
          @Riverstorm said in Top requested arcade games for overlays:
          We do the same in winter in the mountains; all other things you described are something we never had around here. They sound fascinating from some point of view but would imagine daily life becomes extremely complicated if those conditions persist over longer periods.
          • RiverstormR
            Riverstorm
            They are definitely interesting in short bursts. You see things happen you never thought cold would do but overall I like the cold. It may sound weird but after that extreme cold for a few days being above above zero actually feels ok, especially if the sun is shining. :)
            Ok heading out here. I have to be at work early tomorrow as we are starting our implementation phase of our VMWare and SRM upgrade on all our blade servers so I'll be off and on over the next week. Then I'll settle into a routine of upgrading each blade.
            • quicksilverQ
              quicksilver @UDb23
              @UDb23 thank you, looks great! I'll test it tonight.
              • RiverstormR
                Riverstorm
                @UDb23 @quicksilver - My wife let me interrupt her show and do a quick test during a commercial break. It's works good. Meleu's menu is incredibly quick for testing.
                @quicksilver - I still use your Quake stress test when overclocking. It's become my go to for stability testing now. :)
                • quicksilverQ
                  quicksilver @Riverstorm
                  @Riverstorm Thats great to hear. I am still in the process of getting my setup switched over to retropie 4.4 so I havent had a chance to check out the overlay yet. I am upgrading my pi3b to a 3b+ and it should be coming tomorrow so I am definitely running some quake 3 stress testing in the near future :)
                    UDb23
                    @quicksilver
                    Space Fury done & available:
                    quicksilverQ 2 Replies Last reply Reply Quote 2
                    • quicksilverQ
                      quicksilver @UDb23
                      @UDb23 yes! Thank you it looks great!
                      • quicksilverQ
                        quicksilver @UDb23
                        @UDb23 Any idea why I am getting a black screen while using your missile command overlay? I can see the overlay and I can hear the game audio but game-play area is black. Tested without the overlay and the game works fine.
                          Chef Otis
                          hey fellas, anyone have a 4:3 space invaders? searched high and low.. cant find one
                            UDb23 @quicksilver
                            Seems one of the cfg files was messed up.
                            Can you try again now ?
                            BriganeB 1 Reply Last reply Reply Quote 0
                            • BriganeB
                              Brigane @UDb23
                              @UDb23 said in Top requested arcade games for overlays:
                              That's weird I have no problems at all. I'm pretty sure I tried before you changed the cfg file.
                              Systems: Raspberry Pi 0/2/3 Model B+
                              Os: RetroPie 4.5
                              Frontend: Emulationstation & Attract Mode
                                UDb23 @Brigane
                                @Brigane it was setting specific viewport for 1080p. Worked fine on my tv too;maybe he has a different resolution screen. Updated cfg relies on core provided game area instead of fixing coordinates.
                                quicksilverQ 2 Replies Last reply Reply Quote 0
                                • quicksilverQ
                                  quicksilver @UDb23
                                  @UDb23 My Tv is 1080p. Ill have to check if I messed with the video out settings. Nonetheless thanks for fixing it!
                                  • GreenHawk84G
                                    GreenHawk84
                                    Great shooter:
                                    • quicksilverQ
                                      quicksilver @UDb23
                                      @UDb23 so I updated and downloaded it again but the problem persists. I checked and video mode is set to 1080p. Do I need to delete the old one before downloading the new one?
                                        UDb23 @quicksilver
                                        @quicksilver no reason to delete. But just to be sure try deleting. Still same problem of game area covered?
                                        Are the other overlays working ?
                                        • quicksilverQ
                                          quicksilver @UDb23
                                          @UDb23 every other one I have tested has worked fine. It's just this one (so far) that I noticed didn't work right. When I'm next by my pi I will remove the overlay and replace and see if that helps and report back.
                                          Edit: deleting the zip.cfg and then reinstalling took care of the issue
                                            UDb23 @quicksilver
                                            @quicksilver glad it solved. I just reinstalled on my Pi and it worked fine.
