    Top requested arcade games for overlays
    overlayarcadepoll
    594 Posts 34 Posters 723.9k Views
    • HurricaneFanH
      HurricaneFan
      @UDb23 Is there a way for me to add your other overlays to your GitHub repository? So they are all in one place?
        UDb23 @HurricaneFan
        @HurricaneFan Good to know that raspi2png works nicely with overlays.
        Concerning the repository it should be possible but Github is new to me; I have to check.
        Did you create additional overlays ?
        I suppose you need a github account anyway to allow you to access the repository.
        Edit: I misunderstood, you meant my overlays. Yes I will place all of them (old and new) there soon. Just need some free time.
        Please check naming conventions proposed by @meleu so that he can write some script in the future to install the overlays automatically.)
        meleuM 2 Replies Last reply Reply Quote 2
          meleu @UDb23
          @UDb23 Wow! I didn't noticed you created a repository! Good to know it!
            meleu @UDb23
            @UDb23 By the way, you can use spaces in directory names (as we discussed above). Then Burger_Time should be Burger Time. ;-)
              meleu @UDb23
              @UDb23 I've made some Pull Requests to your repository adding some of your files I have here.
              I already adjusted the filenames with the conventions we discussed before.
              To accept the Pull Requests you have to merge them. On the respective Pull Request page, press the "Merge pull request" button:
                UDb23 @meleu
                @meleu Pull requests merged and Burger Time renamed; thanks !
                caver01C 1 Reply Last reply Reply Quote 2
                • caver01C
                  caver01 @UDb23
                  @UDb23 said in Top 10 requested arcade games for overlays:
                  Except that BurgerTime should not have a space in its name ;-) check here:
                  Funny. Some of the marketing materials, cabinet art etc. use BurgerTime, but the owner's manual has a space. Oh well.
                  UDb23U 1 Reply Last reply Reply Quote 2
                    UDb23 @caver01
                    @caver01 Good Point. Renamed to BurgerTime (no space) as in the game marquee.
                    • HurricaneFanH
                      HurricaneFan
                      @UDb23 Is Ms. Pac-Man next on your list of overlays?
                      UDb23U 2 Replies Last reply Reply Quote 0
                        UDb23 @HurricaneFan
                        @HurricaneFan You're lucky. It is already the next in list and almost finished. Will release today.
                          UDb23 @meleu
                          @meleu For some games multiple overlays with different game area size can be available: sidebars only vs scale integer, as an example. These require not only different overlay image but also different cfg files. How do we manage these cases in the repository ? Subfolders of the specific game folder called "Option x" (x is num of the optional overlay) ?
                          Subfolder files would then follow same naming convention as files in the game folder.
                            meleu @UDb23
                            I'm OK with this convention. ;-)
                              UDb23
                              Repository updated with improved DigDug overlay.
                                UDb23 @HurricaneFan
                                @HurricaneFan Here you go!
                                nr. 7 in the Poll
                                Files available in the Overlay repository.
                                HurricaneFanH 2 Replies Last reply Reply Quote 3
                                  UDb23
                                  ... and here's also Nr. 5 : FROGGER
                                  HurricaneFanH 1 Reply Last reply Reply Quote 3
                                  • HurricaneFanH
                                    HurricaneFan @UDb23
                                    @UDb23 You Rock! Thank you!
                                    • HurricaneFanH
                                      HurricaneFan @UDb23
                                      • HurricaneFanH
                                        HurricaneFan @UDb23
                                          UDb23 @HurricaneFan
                                          @HurricaneFan thanks for the screen caps!
                                          HurricaneFanH 1 Reply Last reply Reply Quote 0
                                          • HurricaneFanH
                                            HurricaneFan @UDb23
                                            @UDb23 Thank you for all the hard work you're putting into these overlays. You are just about done with that top 11 list. Have you thought about what other arcade games you might make overlays for?
