    Issues running Dracula X Chronicles PSP
    draculaxcastlevaniapspretropie 4.1.8
    6 Posts 3 Posters 4.1k Views
      solemgar
      Hey there!
      I am having some trouble loading Castlevania Dracula X Chronicles for PSP (Either US or EU versions).
      Game loads up to this point (see screenshot):
      As soon as I press the button , I get back to emulationstation screen. Someone has the same problem with this game? As far I saw on PSPSSP compatibility list, it is supported.
      Pi Model or other hardware: Pi3
      Power supply: Proper
      RetroPie Version Used (3.6, 3.8.1, 4.01 etc.. - do not write latest): 4.1.8
      Built From: Retropie on top of OSMC
      USB Devices connected: Logitech USB wireless keyboard
      Controller used: XBOX 360 wireless
      Error messages received: No errors received
      osmc@osmc:~/RetroPie/roms/psp$ tail -F /dev/shm/runcommand.log
      pure virtual method called
      terminate called without an active exception
      W: file_util.cpp:215: W: IsDirectory: stat failed on /home/osmc/RetroPie/BIOS/PPSSPP/lang/.ini
      I: gl_state.cpp:137: I: GPU Vendor : Broadcom ; renderer: VideoCore IV HW version str: OpenGL ES 2.0 ; GLSL version str: OpenGL ES GLSL ES 1.00
      I: gpu_features.cpp:20: I: Checking for GL driver bugs... vendor=7 model='VideoCore IV HW'
      I: zip_read.cpp:337: I: Not a VFS path: /home/osmc/RetroPie/BIOS/PPSSPP/shaders/defaultshaders.ini . Reading local file.
      I: zip_read.cpp:370: I: Not a VFS path: /home/osmc/RetroPie/roms/psp/PSP/shaders . Reading local directory.
      I: fbo.cpp:194: I: Creating 480 x 272 FBO using separate stencil
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 947: 3934 Aborted /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie``/libretrocores/lr-ppsspp/ppsspp_libretro.so --config /opt/retropie/configs```/psp/retroarch.cfg "/home/osmc/RetroPie/roms/psp/Castlevania - The Dracula X Chronicles (Europe).iso" --appendconfig /dev/shm/retroarch.cfg
      tail: '/dev/shm/runcommand.log' has become inaccessible: No such file or directory
      tail: '/dev/shm/runcommand.log' has appeared; following end of new file
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie``/libretrocores/lr-ppsspp/ppsspp_libretro.so --config /opt/retropie/configs``/psp/retroarch.cfg "/home/osmc/RetroPie/roms/psp/Castlevania - The Dracula X Chronicles (Europe).iso" --appendconfig /dev/shm/retroarch.cfg
      glGetError 0x500
      glGetError 0x500
      Guide used: https://github.com/mcobit/retrosmc
      File: (File with issue - with FULL path): /home/osmc/RetroPie/roms/psp/Castlevania - The Dracula X Chronicles (Europe).iso
      Emulator: (Name of emulator - if applicable): lr-ppsspp\
        solemgar @solemgar
        I checked with other games and they have a similar behavior. They run for a bit, then drop down to menu. I was reading some other posts and they mention updating or installing pspssp (not lr). Any guidance will be greatly appreciated :)
          solemgar
          I am not sure if I am doing it right, but I removed the lr-ppsspp from the packages list, and installed ppsspp from the opt packages, but the games won't even start at all.
          Wish I could update the topic title!
            solemgar
            Regular PPSSSP also fails. It does not even manage to load any ISO.
            Parameters: Executing: /opt/retropie/emulators/ppsspp/PPSSPPSDL "/home/osmc/RetroPie/roms/psp/psy-dbzsbar.iso" 38:40:727 Core/Config.cpp:940 I[LOAD]: Loading controller config: /home/osmc/.config/ppsspp/PSP/SYSTEM/controls.ini 38:40:727 Core/Config.cpp:1296 E[LOAD]: Failed to read /home/osmc/.config/ppsspp/PSP/SYSTEM/controls.ini. Setting controller config to default. glGetError 0x500 pure virtual method called terminate called without an active exception Pixels: 1920 x 1080 Virtual pixels: 1920 x 1080 I: gpu_features.cpp:126: GPU Vendor : Broadcom ; renderer: VideoCore IV HW version str: OpenGL ES 2.0 ; GLSL version str: OpenGL ES GLSL ES 1.00 /opt/retropie/supplementary/runcommand/runcommand.sh: line 947: 8986 Aborted /opt/retropie/emulators/ppsspp/PPSSPPSDL "/home/osmc/RetroPie/roms/psp/psy-dbzsbar.iso"
            I also tried to update both emulators by source instead of binary.
              txutxifel
              Power supply: Aukru 3A
              USB Devices connected: USB wireless keyboard
              Controller used: No yet
              I have same problems with lr-ppsspp and PPSSSP. i tested some games and anyone works. I have installed OSMC system. It will be the reason?
              • I
                imakowski
                I have the same issue. Do you have resolution for this problem?
