    Help with SSelph Scraper
    16 Posts 7 Posters 11.7k Views
      Moco
      Hi everyone, I recently bought a pi 3 and am trying to get this command style thing down. I am having trouble with the included scrapers never finding anything. I went on youtube and found this video:
      now when i exit emulationstation and get to the prompt he says to type this in:
      http://github.com/sselph/scraper/releases/download/v0.7.5-beta.zip
      I tried putting that in my browser pc and it didnt work (video is about a year old)
      Instead, I went to the site and got this:
      http://github.com/sselph/scraper/archive/master.zip
      Ok, so that works.
      To make this short, i got to the CD nes part and when I went to scraper it says something a long the line of scraper not found, I'm not near my pi right now so I can't test anything out but one thing I didn't try was typing the "scraper.go"
      The scraper is on the pi because i see it via FTP , usr/local/bin/master-scraper/
      Thanks in advance.
      FinheadF 1 Reply Last reply Reply Quote 0
      • FinheadF
        Finhead @Moco
        @Moco
        The GamesDB is down has been for the last 5 days or so. You'll have to wait till there back up.
        • herb_fargusH
          herb_fargus administrators
          read the documentation: https://github.com/retropie/retropie-setup/wiki/scraper
            Moco @herb_fargus
            @herb_fargus
            Ok cool, thanks alot. Now is it possible to download the images and transfer it to the pi? If so, where should I go?
            • nc4080N
              nc4080
              So i did the same thing from Moco's original post:
              That worked and the download completed but then i continued follow the video keeping in mind that the zip file name has changed so i type in:
              sudo unzip master.zip scraper -d /use/local/bin/
              I get a message 'caution: filename not matched: scraper. So then I type in:
              sudo unzip master.zip -d /use/local/bin/
              This leaves out 'scraper' in the command line.
              I then go to:
              /RetroPie/roms/snes
              When I am in there I try to run:
              scraper -thumb_only
              But I receive the message:
              -bash: scraper: command not found
              Can you let me know what I am doing wrong here? I'm not too familiar with the command line and I'm sure its something really simple.
              Thanks in advance.
                BuZz administrators
                read the link two posts above yours - there is no need to install it from source or run it manually.
                • nc4080N
                  nc4080
                  Thanks, I found that quitting emulation station takes you to the terminal. From there i entered:
                  cd RetroPie-Setup
                  sudo ./retropie_setup.sh
                  After doing that RetroPie_Setup will run (option 3) and was able to run sselph scraper (option 319). After doing a full scrape, I was getting errors. I notice that 'thegamesdb' is the default scraper. According to this thread that database is down (and has been for a few days) so I changed it to 'OpenVGDB'. I did a scrape for all systems and found some of my ROMS.
                  A question: Is 'thegamesdb' a larger, better resourced DB than 'OpenVGDB'?
                  herb_fargusH M 2 Replies Last reply Reply Quote 0
                  • herb_fargusH
                    herb_fargus administrators @nc4080
                    @nc4080 yes thegamesdb is a little more extensive but their hosting situation right now isnt the greatest which is why we included alternate databases for these times when thegamesdb is down.
                    nc4080N 1 Reply Last reply Reply Quote 0
                    • nc4080N
                      nc4080 @herb_fargus
                      @herb_fargus OK, so at the moment is there only 'thegamesdb' and 'OpenVGDB' for the retropie project?
                      Are there other DB's or plans to add in other DB's in the future?
                      • herb_fargusH
                        No there are not any plans currently unless something better becomes available and someone is willing to code it in.
                        • nc4080N
                          nc4080 @herb_fargus
                          @herb_fargus Is there any indication when 'thegamesdb' might be coming back online? Does it go down very often?
                          • FloobF
                            Floob
                            @nc4080
                            Hopefully they'll keep current updates posted here so you can see if it will work in the future:
                            https://twitter.com/thegamesdb?lang=en-gb
                            • herb_fargusH
                              @nc4080 read the wiki page.
                                Moco @nc4080
                                Every time I type in Sudo I get something like sudo does not exist. What am I doing wrong?
                                • herb_fargusH
                                  herb_fargus administrators @Moco
                                  @Moco case sensitive
                                    SweetFish
                                    Are these hash not found errors because thegamedb is down?
                                    2016/04/11 13:52:45 INFO: Checking for new hash.csv.
                                    2016/04/11 13:52:45 INFO: hash.csv "5db5b721700b9c87ec273a7820f917ce" up to date.
                                    2016/04/11 13:52:48 INFO: Starting: /home/pi/RetroPie/roms/nes/Contra.nes
                                    2016/04/11 13:52:48 INFO: Starting: /home/pi/RetroPie/roms/nes/Popeye.nes
                                    2016/04/11 13:52:48 INFO: Starting: /home/pi/RetroPie/roms/nes/RUSHNATK.NES
                                    2016/04/11 13:52:48 INFO: Starting: /home/pi/RetroPie/roms/nes/Super Mario Bros. 2.nes
                                    2016/04/11 13:53:03 ERR: error processing /home/pi/RetroPie/roms/nes/Popeye.nes: hash not found
                                    2016/04/11 13:53:03 INFO: Starting: /home/pi/RetroPie/roms/nes/Super Mario Bros.nes
                                    2016/04/11 13:53:03 ERR: error processing /home/pi/RetroPie/roms/nes/Contra.nes: hash not found
