    Shaders hotkey help
    3 Posts 2 Posters 1.7k Views
    • TwoGuidosGamingT
      TwoGuidosGaming
      Sorry if this has been posted somewhere on the forums.
      How can I set up my hotkey to cycle through shaders?
      Im using logitech f310. I switched my hot key to the logitech button which is "8"
      I would like to use the left and right analog buttons to cycle through shaders .(thumb buttons)
      Thanks in advance!
      heres is my config:
      input_device = "Logitech Gamepad F310"
      input_driver = "udev"
      input_r_y_plus_axis = "+4"
      input_l3_btn = "9"
      input_r_x_minus_axis = "-3"
      input_r_btn = "5"
      input_save_state_btn = "5"
      input_l2_axis = "+2"
      input_start_btn = "7"
      input_exit_emulator_btn = "7"
      input_l_y_minus_axis = "-1"
      input_l_btn = "4"
      input_load_state_btn = "4"
      input_up_btn = "h0up"
      input_r_y_minus_axis = "-4"
      input_a_btn = "1"
      input_b_btn = "0"
      input_reset_btn = "0"
      input_down_btn = "h0down"
      input_r2_axis = "+5"
      input_l_x_plus_axis = "+0"
      input_l_y_plus_axis = "+1"
      input_r3_btn = "10"
      input_right_btn = "h0right"
      input_x_btn = "3"
      input_menu_toggle_btn = "3"
      input_select_btn = "6"
      input_enable_hotkey_btn = "8"
      input_l_x_minus_axis = "-0"
      input_y_btn = "2"
      input_left_btn = "h0left"
      input_r_x_plus_axis = "+3"
      • TwoGuidosGamingT
        TwoGuidosGaming
        Figured it out :)
        input_shader_next_btn = 10
        input_shader_prev_btn = 9
          BuZz administrators
          http://commonmark.org/help/ (makes configs more readable if wrapped in a code block)
