Tronkyfran theme issue
Can anyone help with my issue? Only snes which doesn't show background theme. Is there an issue with the script as I've reinstalled a few times but nothing.
@swandog What version of retro pie are you running? The white background issue should be resolved in newer builds.
@swandog Ok. Not sure on the exact path here but from my memory, you will want to check if the SNES background file is on your pi.
If you installed the theme manually through FTP:
/home/pi/.emulationstation/themes/tronkyfran/snes/art/snes_art_blur.jpgIf you installed the theme through the installer, I think this the location:
/etc/emulationstation/themes/tronkyfran/snes/art/snes_art_blur.jpg -
@HurricaneFan ok i will double check. Pretty sure it is on there though as I even tried changing the theme.xml file to use the UK snes background (...blur3.png or .jpg). I downloaded all the files to my pc from tronkyfran folder to see what they were.
@swandog If you can show what is in that theme file, we can get it working quickly.
Update your setup script reinstall emulationstation from binary. Then try again and see if persists
@HurricaneFan will send you this later. Thanks
@herb_fargus hi, will doing this lose any of my setup ?
@swandog if you do not power off your pi in mid installation of the downloaded packages is no thing to worry at all
@sergioad @herb_fargus I've updated setup script, how do I reinstall emulationstation?
@swandog Manage packages > Main packages > emulationstation and there uninstall and then install
@sergioad @herb_fargus @HurricaneFan reinstalled and all sorted now. Thanks all
@swandog You are wellcome
