    HELP with RetroPie in game controls when using Adafruit-Retrogame
    2 Posts 2 Posters 643 Views
      mastblast09
      Hello!
      so i just finished building the SuperGameGirl mod can be found HERE that was posted by Cristov9000
      everything came along fine and everything works. when you enter Emulation Station i setup the buttons and everything withing ES works fine. when i go in to any of the games none of the buttons are recognized. I have made sure that
      SUBSYSTEM=="input", ATTRS{name}=="retrogame", ENV{ID_INPUT_KEYBOARD}="1"
      is in the
      /etc/rc.local
      i also tried going from retropie v3.7 to 3.6 but still does it.
      am i missing something? i appreciate all the help!
      Pi Model: 2 B V1.1
      RetroPie Version Used: V3.6 and V3.7
      Built From: SD Image
      USB Devices connected: Logitech K330 keyboard
      Controller used: none
      Error messages received: none
      Guide used: build guide used HERE and Retropie install guide used HERE
      • Jakob HolzJ
        Jakob Holz
        Hi mastblast09,
        I'm experiencing the very same problem.
        Have you figured out how to solve it?
        If yes, please tell me.
        Thank you in advance
