    USB Controller player order
    12 Posts 6 Posters 19.6k Views
      djgra79 @herb_fargus
      @herb_fargus Thanks.
      So do I only need to add in the "input_playerxx_joypad_index = xx" lines or copy & paste the whole file (each key mapping) also?
      • herb_fargusH
        herb_fargus administrators @djgra79
        @djgra79 well as you are only changing the index and not the controls you'll only want to put in the index info. we really need to add it as an option to the configuration editor tbh
        And as you mentioned you'll want it different for different systems you'll want to set it in the per system retroarch.cfg rather than the overall retroarch.cfg as mentioned in the aformentioned wiki page
        D RionR 2 Replies Last reply Reply Quote 1
          @herb_fargus Does this look right because it doesn't appear to be working:
          https://www.dropbox.com/s/4n72s2b17sewrbi/2016-05-07 13.58.35.jpg?dl=0
          • herb_fargusH
            @djgra79 yes that looks correct but it will only work with retroarch configs. If you're using a non libretro emulator for the n64 of course it will not work.
              @herb_fargus I'm using mupen64plus-gles2n64 as it is the only one out of the 4 available that runs the games (Mario Kart 64) smoothly
                BuZz administrators @djgra79
                @djgra79 that isn't a retroarch/libretro emulator.
                  djgra79 @BuZz
                  @BuZz So does this mean the only way to change controllers for P1 & 2 is to physically swap USb cables?
                    JoargTheBard
                    Any way to assign indexes for non-retroarch emu's? I'm having a problem with my Bluetooth controllers being assigned to p3 and p4
                    • W
                      wetriner @djgra79
                      @djgra79 You should be able to make some manual changes in your mupen64plus.cfg in /opt/retropie/configs/n64. The bottom half of the file is dedicated to controller options.
                      # Controller configuration mode: 0=Fully Manual, 1=Auto with named SDL Device, 2=Fully automatic
                      mode = 2
                      Feel free to change the SDL joystick name and set the mode to 1, and those settings should stick. If you rearrange the names to how you want them SDL1, SDL2, etc.. you should have control over player number without a physical port swap.
                      • RionR
                        Rion @herb_fargus
                        @herb_fargus said in USB Controller player order:
                        Yes please :)
                        FBNeo rom filtering
                        Mame2003 Arcade Bezels
                        Fba Arcade Bezels
                        Fba NeoGeo Bezels
