    Problem with USB hub
    4 Posts 3 Posters 1.6k Views
      space invader
      Hi.
      I bought a usb hub to use with my pi2 and although in my pc it works perfectly, in the pi only one out of four ports works.
      What could be the problem? This hub does not work with the pi? Alimentation problems?
      Thanks in advance.
        Twitch0815
        Is it a powered USB Hub? The Raspberry pi does not have the power to make a non powered USB Hub work. It will have to have its own power supply in order to work with the Raspberry pi.
          space invader @Twitch0815
          Ok, I will try a powered one. Thanks.
            superomegabeto
            @Twitch0815 said in Problem with USB hub:
            Hello, did you solve it? I have the same problem.
