    Sound stutter on Minish Cap (GBA) on RPI2
    5 Posts 3 Posters 2.8k Views
      Arcuza
      I'm trying to play Minish Cap with lr-vba-next, but the sound stutters.
      Is someone able to paste a configuration that solves the sound problem?
      Thank you very much for your support!
      CharcoC 1 Reply Last reply Reply Quote 0
      • CharcoC
        Charco @Arcuza
        @Arcuza I put my RetroPie 3.7 image from my Pi 3 on my Pi 2 to gift to my friend this morning and noticed some sound issues present on the Pi 2 with lr-vba-next which were not on the Pi 3.
        I changed the default emulator for GBA to lr-mgba and the sound was perfect.
        Perhaps you could try that emulator instead?
          Arcuza @Charco
          @Charco thank you, I'll try that later today. I were hoping to be able to change to 22 kHz, because that has solved me a lot of problems through the years. Do you know how to do that?
          CharcoC TwoGuidosGamingT 2 Replies Last reply Reply Quote 0
          • CharcoC
            Charco @Arcuza
            @Arcuza I can't do it from the RetroArch menu, maybe you can do it in the config file but I haven't checked.
            • TwoGuidosGamingT
              TwoGuidosGaming @Arcuza
              @Arcuza navigate to samba shares configs\gba\retroarch.cfg
              add this line to the top
              audio_out_rate = 22000
              make sure its above this line of text...
              Settings made here will only override settings in the global retroarch.cfg if placed above the #include line
              This should only affect the gameboyadvance emulator
              if you want it for all emulators you have to navigate to /opt/retropie/configs/all/retroarch.cfg (i use filezilla for this) or ssh into it
              Not sure but i think this is how to do it, if someone else can confirm
