    Help please lr-snes9x next slow
    5 Posts 4 Posters 4.9k Views
    • elf0E
      elf0
      Hello, I recently trying to use the emulator lr-snes9x next and is very slow in all games.
      I'm using
      • Raspberry PI2 Model B;
      • SD Card 32gb Class 10;
      • Retropie 3.6 (I also tested with 3.7);
      • No overclock;
      • No shaders
      Could anyone tell me what is happening? Please.
      • tribunal88T
        tribunal88
        I think I may be experiencing the same issues. I'm using lr-snes9x-next on the Pi3 and performance is very bad compared to other emulators on certain games. The interesting thing is that it works just fine using the same hardware on a version of RetroPie 3.6 that is packaged for Berryboot. I'm not sure if this might be a Raspien issue. I should also mention I'm multi-booting with NOOBs.
        • tribunal88T
          tribunal88
          Mystery solved (for me anyway). Add the following to /etc/rc.local:
          echo ondemand > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
          echo ondemand > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
          echo ondemand > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
          echo ondemand > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
          Found the fix here:
          https://github.com/RetroPie/RetroPie-Setup/issues/1251
          • RionR
            Rion @tribunal88
            @tribunal88 said in Help please lr-snes9x next slow:
            Found the fix here:
            This should be added to the wiki until a fix for Jessie is out.
            FBNeo rom filtering
            Mame2003 Arcade Bezels
            Fba Arcade Bezels
            Fba NeoGeo Bezels
              BuZz administrators
              There is no known probem on Jessie - and nothing I can do without more information - the governor is automatically set to ondemand on my system.
