    Shutdown RetroPie/Pi using OSMC Remote Control Button
    osmc remotedetect keystrok
    5 Posts 1 Posters 859 Views
      serenity
      Hello,
      This is my first post.
      I am trying to restart Retropie using an OSMC remote home button to calls a bash script (not using the emulation station menu option). I think the home button issues a standard keyboard ”Escape” keystroke if I am not mistaken. I have been trying to do this for the past 3 days but to no avail.
      I managed to do a similar thing easily in Raspbian by editing “Openbox” keyboard shortcut file but retropie doesn’t seem to have Openbox. I even tried to install openbox but it didn’t work. I know retropie is built on raspbian lite but I don’t want to go through the process of installing pixel desktop, openbox and such.
      I tried several solution listed below and I know one of them should work but I couldn’t manage to do it and need help.
      1. Bash & Python
        I managed to read keystrokes but only in Terminal and not in Retropie GUI
      2. Xbindkeys
        Seems to need X windows or such
      3. Tkinter
        Like Bash & Python Worked in Terminal
      4. PyGame
        Worked on raspbian but required a window to be drawn and this will cause issues in retropie
      5. Finally tried /dev/input/by-path approach it seemed crude and should work but it didn’t for some reason
        I think one of the above hold the solution but I couldn’t nail it. I would appreciate a working code samples that will let me accomplish this task.
      Thanks in advance
        serenity
        Touch question I reckon.
        I managed to solve the issue using the /dev/input/by-path approach.
        I have found a script online and adapted it.I will post it shortly.
          serenity
          Here is the script I came up with. I used a base script for the internet and adapted it to my needs. I also added ability to find keyboards rather than having to input them manually into script and also added threading so you can monitor all keyboards in background.
            serenity
            # code block
            #!/usr/bin/env python
            import string
            import os
            import sys
            import time
            import threading
            # pip install evdev
            from evdev import InputDevice
            from select import select
            # Set function to be called for each keyboard
            def keyDetectFunc( fullpath ):
                # look for a /dev/input/by-id/usb...kbd or something similar
                #DEVICE = "/dev/input/by-id/usb-USB_USB_Keyboard-event-kbd"
                DEVICE = fullpath
                dev = InputDevice(DEVICE)
                while True:
                    # wait for keypad command
                    r, w, x = select([dev], [], [])
                    # read keypad
                    for event in dev.read():
                        if event.type==1 and event.value==1:
                            # do something with this key press
                            print ("KEY CODE: ", event.code)
                            if event.code == 1:
                               os.system('sudo shutdown -r now')
                return;
            # Return list of all connected input devices
            path = "/dev/input/by-id/"
            dirs = os.listdir(path) # returns list
            # This would get all files in dir and filter out Keyboards only
            for file in dirs:
               if ("Keyboard" in file) or ("kbd" in file):
                print file
                keyfile = file
                fullpath = path + file
                #Call detection funtion in background
                keydetect_thread = threading.Thread(target=keyDetectFunc, args=(fullpath,))
                keydetect_thread.start()
              serenity
              Also you need to install the following for code to work:
              sudo apt-get install python-dev python-pip gcc
              sudo apt-get install linux-headers-$(uname -r)
              sudo pip install evdev
              Note it worked without installing the header i.e 2nd satement
              Then you can call it on start up via a cron such as:
              @reboot python /home/pi/scripts/keyreboot.py &
              Remember to give the file execution permisions
