    Retroarch help with controller
    2 Posts 1 Posters 1.0k Views
      pierpa86
      Hi at all, I can not get out of this problem, I'm trying to use a joystick with 2 axes seen from linux (retropie) as /dev/input/js0,i can manualy configure it on mame but retroark keeps telling me no joypad Detected in autodect screen, i try to use js0 only for directional movements and keyboard for button
      thanks in advanced for any support.
      sudo jstest /dev/input/js0
               Driver version is 2.1.0.
               Joystick (python-uinput) has 2 axes (X, Y)
               and 0 buttons ().
               Testing ... (interrupt to exit)
               Axes:  0:  5170  1:  7281
      this is the driver in python
          #!/usr/bin/python
               import spidev
               import time
               import os
               import uinput
          # Open SPI bus
                  spi = spidev.SpiDev()
                  spi.open(0,0)
         # Function to read SPI data from MCP3008 chip
         # Channel must be an integer 0-7
                  def ReadChannel(channel):
                  adc = spi.xfer2([1,(8+channel)<<4,0])
                  data = ((adc[1]&3) << 8) + adc[2]
                  return data
               device =uinput.event([
                    uinput.ABS_X+(0,900,0,0),
                    uinput.ABS_Y+(0,900,0,0),
              joy_x=1
              joy_y=2
        while True:
      joy_x_value=ReadChannel(joy_x)
      device.emit(uinput.ABS_X,joy_x_value,syn=False)
      joy_y_value=ReadChannel(joy_y)
      device.emit(uinput.ABS_Y,joy_y_value)
      time.sleep(0.020)
        pierpa86 @pierpa86
        @pierpa86
        solved... emulation station cant detect joypad with no buttons, you need to use joypad with at least 1 button for detect.
