    Changing default volume setting from 77%
    volume control
    6 Posts 2 Posters 3.7k Views
      Ponny
      I can't for the life of me figure out how to change the starting sound to be 100% instead of 77%. Any idea how I adjust that setting so I don't have to change it each time I boot?
        edmaul69 @Ponny
        @Ponny press start while in emulationstation. Go into sound setting. Scrollup from 77 to 100
          Ponny
          I do that but I'd like to be set permanently. When I do it that way, it goes back to 77 on restart.
            edmaul69 @Ponny
            @Ponny this should fix it unless you use berry boot or noobs or something else im not familiar with. I only know the standard retropie image. you need to press f4 on a keyboard to to get to the command line. Then type:
            sudo chown -R pi:pi /opt/retropie/configs/all/emulationstation/
            then restart and change volume.
              Ponny
              Okay. Going to give it a shot tonight when I get home :-)
                Ponny
                That worked. Cheers.
