    Audio issue
    audio issues
    4 Posts 3 Posters 2.6k Views
      Ghost-Note
      Can anyone explain what this error means? I'm using 4.1.14, a Pi 3 and audio is set to 3.5mm jack. Audio works on every system I'm using except for Dreamcast.
      ALSA lib pcm.c:7843:(snd_pcm_r
        edmaul69 @Ghost-Note
        @Ghost-Note i dont have audio on dreamcast either. Not sure why.
          Ghost-Note @edmaul69
          @edmaul69 Thanks for the heads up, maybe this is more of a known issue than I realize. The good news is, games seem to play really smoothly at least.
          Gig76G 1 Reply Last reply Reply Quote 0
          • Gig76G
            Gig76 @Ghost-Note
            @Ghost-Note I ran into this audio issue too for Reicast emulator. I dug into this issue this weekend and changed the following Reicast configuration files to resolve my Alysa driver related issue. Hope this helps!~
            • Located in: /opt/retropie/configs/dreamcast There's 2 config files i.e. (emulators.cfg, emu.cfg) I recommend making backups those before proceeding.
            • In "emu.cfg" verify the following is set to [audio] disable = 0
            • In "emulators.cfg" Append the following statement to configuration file and save:
            reicast-audio-alsa = "CON:/opt/retropie/emulators/reicast/bin/reicast.sh alsa %ROM%"
            • Now you need to choose "reicast-audio-alsa" as default option in Runcommand Launch Menu. https://github.com/retropie/retropie-setup/wiki/runcommand
            Quote: "No Problems, Only Solutions"
