    New USB stick won't auto-load roms into my RPi....
    usb driveroms
    5 Posts 3 Posters 1.5k Views
      joeljoel1947
      So I upgraded USB sticks to a new USB 3.0 high-speed one to transfer ROMS from my PC to the Pi. My old slow stick would auto-load the roms with the light flashing. The new one will not auto load for some reason---light flashes twice then that's it. I copied everything from the old stick to the new one so it's identical so I'm stumped. Is there a way to manually put the ROMS into the Pi somehow? Instructions? The new stick is like 5 times faster then my old one so I'd like to try to utilize it. Thanks in advance!
      rbakerR P 2 Replies Last reply Reply Quote 0
      • rbakerR
        rbaker @joeljoel1947
        @joeljoel1947 said in New USB stick won't auto-load roms into my RPi....:
        Yes, it's all in the wiki....
        https://retropie.org.uk/docs/Transferring-Roms/
        https://winscp.net/eng/download.php
        https://www.siteground.com/tutorials/ssh/ssh_winscp.htm
          joeljoel1947
          Thanks rbaker! I shall begin my reading! :)
            PetroRie @joeljoel1947
            The most easiest way to transfer them in my opinion is via the network. If you;re on windows, you need to type in the following in the explorer bar: \retropie
            And hit enter. You'll see a couple folders, open up the roms folder and the folder of the console you wan to upload the games, copy 'n paste the zip files.
              joeljoel1947 @PetroRie
              Thanks! That's the goal for me!
