    PI 3 + PS3 Bluetooth controller freeze fix. UPDATED
    43 Posts 16 Posters 29.2k Views
      smoothmalik @Rascas
      @Rascas
      sudo apt-get update && sudo apt-get dist-upgrade
      sudo apt-get install raspberrypi-sys-mods
      worked like a charm!!! THANKS
      • PokeEngineerP
        PokeEngineer
        You can close this issue now...
        I have updated the Bluetooth page on the wiki: https://github.com/RetroPie/RetroPie-Setup/wiki/Setting-up-a-Bluetooth-controller
        Don't sweat it.
        • Z
          zupi
          After applying all the aforementioned updates and even some recipes combining a mix of them, I still get freezes on psx games as soon as i disconnect the usb cable and go all the way wireless. The rest of the setup seem to work fine. :/
