    Problems with chromium in pixel desktop
    flash player
    1 Posts 1 Posters 1.0k Views
    • W
      Wulf
      First of all, I wanted to say hi, and thanks for all of the hard work and progress put into retropie!
      I'm inexperienced with raspberry pi and linux, but I tried to do what I could before coming here. The problem that I'm running into is that Chromium in Pixel doesn't seem to have flashplayer. I believe the newest version of pixel is supposed to have pepperflash installed, but updating Pixel from the terminal (in pixel of course) with the below code doesn't solve the problem:
      sudo apt-get update
      sudo apt-get dist-upgrade
      sudo apt-get install -y rpi-chromium-mods
      sudo apt-get install -y python-sense-emu python3-sense-emu
      sudo apt-get install -y python-sense-emu-doc realvnc-vnc-viewer
      The other issue is that going to google sites gives me this error:
      This site can't provide a secure connection
      chrome.google.com sent an invalid response.
      ERR_SSL_PROTOCOL_ERROR
      I've updated the setup script and installed pixel from Configuration / Tools >> Raspbiantools >> Install Pixel Desktop Environment using this guide (https://github.com/retropie/retropie-setup/wiki/FAQ). I also upgraded the Raspbian packages. Any help or suggestions is much appreciated. Thanks in advance.
      systems information:
      Raspberry pi 3 model B with KOOKYE 3.5'' Touch Screen 480x320 LCD
      2.5 amp power supply
      RetroPie version 4.1.14
      imaged SD card with retropie-4.1-rpi2_rpi3.img
      USB devices: Gear Head Windows mini smart touch keyboard
      Controller: generic wired xbox 360 controller
