    crashes, lag help please :-)
    crashes
    4 Posts 3 Posters 965 Views
    • O
      Opunui
      Just got my rasberry pi 3 set up, got multiple games, few of them lag pretty good and make them unplayable. I have not overclocked or adjusted any settings. Completely stock settings. Mario cart has been having crashes while playing 4 player ect. wondering if any advice? thanks
        mediamogul Global Moderator @Opunui
        @Opunui
        In order to help you, you'll need to supply the information requested below.
        I wouldn't expect too much from the N64 emulation, especially when utilizing four player support. N64 emulation on it's best day is spotty. On the Pi, it's a miracle it works as well as it does and trying to bring in three other players is really asking too much in most cases.
        • Lyle_JPL
          Lyle_JP
          Some lag could be introduced by your TV set. Make sure you are using your TV's "game mode" if it has one and turn off as much post-processing (motion smoothing, noise reduction, etc.) as you can.
          • O
            Opunui @mediamogul
            @mediamogul heyyyy so its this kit right here
            https://www.amazon.com/Raspberry-Essentials-Kit-board-Connectivity/dp/B01LWVVMUI/ref=sr_1_7?s=pc&ie=UTF8&qid=1488043332&sr=1-7&keywords=rasberry+pie+3
            using xbox 360 controllers (they connected real easy)
            no error messages just a straight freeze every 3 races or so. Tried 1 player nfl blitz its just extremely choppy. Using the guide off this website the video they supply. Using Retro pie 4.1
