    Famicom (not Mini) build (WIP)
    famicomfamicom minines
    264 Posts 11 Posters 158.1k Views
    • FlyingTomahawkF
      FlyingTomahawk @obsidianspider
      @obsidianspider
      Thanks.
      Let's see what PayPal can do first.
      • FlyingTomahawkF
        FlyingTomahawk
        So after I filed a claim through PayPal guess what.
        I received a shipping confirmation that the Mausberry was shipped yesterday, April 15.
        When I placed the order it was clearly saying in stock. Because I applied for a notification as soon the item is available.
        I kinda have the feeling that my order was forgotten and if I never would have filed a claim through PayPal I would never have received the shipping confirmation.
        Well, it sucks big time but let's hope now that the circuit arrives as quick as possible so that I can finally build the Famicom.
        Kinda disappointed though, didn't receive any apology for the delay which was over a month!
        He/they can consider them lucky to have such a unique product otherwise they would be very quick out of business. Someone should create a similar poduct and do a better job.
          obsidianspider @FlyingTomahawk
          @FlyingTomahawk I have to wonder how complex that circuit is. It can't be doing a whole lot. If someone made a DIY set of instructions on how to make one yourself I'd be all about it.
          • spruce_m00seS
            spruce_m00se
            @FlyingTomahawk said in Famicom (not Mini) build (WIP):
            Mausberry
            from the looks of it, its just a push switch onto the GPIO pins to shut the pie down with a script, and then a chip thats cutting off the power supply via the passthrough.
            Im fairly sure you could do this with an arduino, a push switch and an hours coding.
            L 1 Reply Last reply Reply Quote 1
            • L
              liquidzoo @spruce_m00se
              @spruce_m00se said in Famicom (not Mini) build (WIP):
              Mausberry
              Probably wouldn't even need the hours worth of coding. Mausberry offers the script themselves
                Srfrboybob @liquidzoo
                @liquidzoo
                I used a powerblock. The space was a bit tight so I had to solder directly to the power block pins on top but I was able to place directly on the pi with no problem and no coding. I just found this thread and o was super happy. I had built a famicom 3pi this last year. I will follow with some pics. I ended up using the 8bitdo famicom styled Bluetooth controllers. They fit perfectly in the built in controller holders with no mods. I purchased the pair labels 1 and 2. Love the build and all my friends are really confused by the console.
                FlyingTomahawkF 1 Reply Last reply Reply Quote 1
                • FlyingTomahawkF
                  FlyingTomahawk @Srfrboybob
                  @Srfrboybob
                  Nice!
                  Yeah, let's see those pictures, we can use any motivation here.
                  If you read through this thread here you'll see that I too got the 8bitdo FC30 Player I & II controllers. They fit like a glove.
                  I have everything setup and configured. The only thing left is that Mausberry circuit.
                  I want to use that original power switch of the Famicom that is the only reason I kept stand this whole Mausberry ordeal.
                  K S 2 Replies Last reply Reply Quote 0
                    klachow @FlyingTomahawk
                    I've been really digging this build log, and I'm looking forward to seeing the finished console . I've been really tempted to do a build like this. I keep watching junk Famicoms on ebay, etc... I think my favorite thing about a Famicom Retropie build is that it keeps track of the controllers. However my least favorite thing is that it only keeps track of two controllers. So I started imagining a 4 controller Famicom. 3D printing is the obvious method to realize something like this. I found this 3D file for a Famicom on Thingiverse, which the creator was generous enough to make GNU GPL CC. I then "remixed" it a bit to come up with this:
                    0_1492636533912_upload-f4163ba4-9ee7-4c17-b953-bb8054352d3a
                    I'm not sure if I made enough space for the inner controllers. I'll probably print just a section to try it out first. It is likely going to be a while before I get around to 3D printing it. Otherwise I would have started a build log of my own. I hope you don't mind me posting this here on your thread for now.
                      Srfrboybob @FlyingTomahawk
                      @FlyingTomahawk Sorry it took a bit but here are my pics. I used a control block because I had it but I used the power block setup. Using bluetooth controllers has been an issue in the past with the controller assigning with the control block. I ran into issues when I decided to go wireless on my Pitendo build.
                      • FlyingTomahawkF
                        FlyingTomahawk
                        @obsidianspider
                        Its been a while but today I decided to move my ass and get this Famicom build done.
                        So before putting everything in place I wired up the Mausberry and ran the Mausberry script.
                        I connect all the cables and adapters and move the switch to ON. Pi Zero powers up nicelly and I can play games and do the usual.
                        Now I power down the Pi by moving the switch to its OFF position and here is were my trouble starts. When the switch is in OFF mode the Pi keeps rebooting and rebooting in a loop all the time until I move the power switch back to ON and then it shuts down.
                        So what the hell did I do wrong?
                        Soldered the original Famicom switch to SW + and - and connected the IN and OUT wires to GPIO 23 and 24.
                        Is there anything else?
                        • spruce_m00seS
                          spruce_m00se
                          if you instaled a switch script that is meant for a momentary switch and you have latching switch then that is your problem,
                          a momentary switch will only connect the gpio to ground whilst being pushed, then when you push it again it powers the pi, then shuts down etc,
                          if you used the original power switch then the script wil see it it as though you have the switch pressed all the time.
                          FlyingTomahawkF 1 Reply Last reply Reply Quote 0
                          • FlyingTomahawkF
                            FlyingTomahawk @spruce_m00se
                            @spruce_m00se
                            Thanks for your reply and help.
                            I am not so savvy with all this switch stuff. I just installed the setup script that Mausberry offers in their install manual so not sure for what kind of switch that script is. A momentary switch is a switch that has 3 pins (only 2 connected) and a non-momentary switch is a switch like an Arcade stick button from Sanwa?
                              edmaul69 @FlyingTomahawk
                              @FlyingTomahawk an arcade button is a momentary switch. Both mementary and non momentary can have 2-3 pins. On an arcade momentary button you have n.o. and n.c. Normally open and normally closed. If you wire to the normally open then when you press down it activates. Whe it is depressed (pushed up) it activates the normally closed. Some things require a button being detected pressed when you arent pushing it down. Not very common in an arcade to use the nc.
                              • FlyingTomahawkF
                                FlyingTomahawk @edmaul69
                                @edmaul69
                                Thx for explaining.
                                So what kind of switch is inside a Famicom? Or SNES?
                                  @FlyingTomahawk the power switch is non momentary. The reset is a momentary. Momentary meaning it only stays activated for a moment. So anything even like keyboard keys or your controller buttons that are only pressed for a moment and not permanent is a momentary switch.
                                  • FlyingTomahawkF
                                    @edmaul69
                                    So non-momentary switch it is.
                                    So this script is useless?
                                    '#!/bin/bash
                                    #this is the GPIO pin connected to the lead on switch labeled OUT
                                    GPIOpin1=23
                                    #this is the GPIO pin connected to the lead on switch labeled IN
                                    GPIOpin2=24
                                    echo "$GPIOpin1" > /sys/class/gpio/export
                                    echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
                                    echo "$GPIOpin2" > /sys/class/gpio/export
                                    echo "out" > /sys/class/gpio/gpio$GPIOpin2/direction
                                    echo "1" > /sys/class/gpio/gpio$GPIOpin2/value
                                    while [ 1 = 1 ]; do
                                    power=$(cat /sys/class/gpio/gpio$GPIOpin1/value)
                                    if [ $power = 0 ]; then
                                    sleep 1
                                    else
                                    sudo poweroff
                                    fi
                                    done
                                      @FlyingTomahawk i am assuming that it wont work for you. Im not familiar with the mausberry though.
                                      • FlyingTomahawkF
                                        FlyingTomahawk
                                        Yeah, script seems to be not working with my current setup.
                                        Here pics of the current switch and setup.
                                        I also have a PowerBoost 500 which I think can also be used to switch ON/OFF a RPi right?
                                        At least it is used here in this Pi Zero in a SNES controller build.
                                        • FlyingTomahawkF
                                          FlyingTomahawk
                                          UPDATE
                                          I tried the Mausberry switch on my RPi 3 this time and who would have thought it does work. So it looks like that the Mausberry or/and Mausberry script won't work with my Pi Zero.
                                          Guess I'll have to figure out a different way then.
                                            @FlyingTomahawk
                                            Good to see you're back on the project! I thought maybe a mountain of Gameboys crushed you during a recent trip to Hard-On! ;)
                                            You said you have a PowerBoost 500C in the mix. Where is that in the circuit? I don't see it in your photos? I'm pretty sure the Zero in a controller build you linked to is just using the switch to cut power to the Pi. It's not triggering a soft shutdown like the Mausberry is.
                                            The switch you have is not a momentary switch. It's a "latching switch" in that you flip it to one position and it stays there. That said, the Mausberry will automatically detect if the switch is a momentary one or a latching one. That's all taken care of in hardware, so the script is not the issue.
                                            The script is really just detecting the state of the GPIO pins and when one drops in voltage due to the Mausberry not sending current anymore, it triggers a shutdown command.
                                            You said that it works with a Pi 3, so we assume that the Mausberry itself is "good", and while I've not tried one with a Zero, I don't see why it wouldn't work, unless the GPIO pins are either configured differently in your build (I don't think so) or that something is not being detected properly.
                                            I'm thinking that the best way to troubleshoot this would be to tweak the script to do something else instead of sudo poweroff or to somehow monitor the state of the GPIO pins. I'm not a programming or hardware wizard, so I'll have to think on it a bit, and it's not quite 7 AM yet.
                                            To confirm that your script isn't wonky, this is the working script that I just copied from my Genesis USB hub Pi. Granted, that's with a Pi 3, but still.
                                            #!/bin/bash
                                            GPIOpin1=23
                                            GPIOpin2=24
                                            while [ 1 = 1 ]; do
                                            sleep 1
                                            else
                                            sudo poweroff
                                            fi
                                            done
                                            I really think it's a matter of the GPIO not being detected properly, not that the Mausberry is being weird.
