    Famicom (not Mini) build (WIP)
    famicomfamicom minines
    264 Posts 11 Posters 164.6k Views
    • FlyingTomahawkF
      FlyingTomahawk @spruce_m00se
      @spruce_m00se
      You are a genius!
      I used the previous microusb adaptor with the new ac adaptor (5V 4A) and now it runs just fine.
      Saw the lighting bolt for a brief moment only.
      Now I can use any theme with or without video and run any emulator without issues.
      No lighting bolt and no temp sign. Temp sign won't show since I run a tiny fan at 3.3V over the main heatsink.
      Here the setup (not installed yet)
      (AC adaptor, 2.1 jack to microUSB, microUSB male/female extension)
      • spruce_m00seS
        spruce_m00se
        you should consider soldering a barrel jack to the pi and connecting the power supply directly to it. that would be better.
        I have read somewhere that the 3.3v GPIO pin on the Pi cannot handle the current draw of a fan, maybe its not the best idea to use that pin, I use it, but maybe mine will die.!!
        • spruce_m00seS
          spruce_m00se
          I actually just looked up the 3.3v issue, and I found info stating that the rail has at least 500ma capability and rund from a different voltage regulator on the board, I dont know if thats true as it was just in some posts and not backed up with evidence, I hope its true.
          • FlyingTomahawkF
            FlyingTomahawk
            Yeah, I will add a barrel jack later on my new Famicom case. This one is not the best looking work.
            I still got 3 Famicoms around to bleach and mod. I broke not needed pieces out with a pench tool which doesn't look nice I should buy a Dremel or similar for better results.
            Regarding the fan, I haven't encountered any issues thus far. My RPi is nice and cool inside the Famicom.
