    Does Retropie 3.7 on RPI3 actually work for anyone?
    18 Posts 10 Posters 5.0k Views
      smoothmalik
      Coming from RPI2b running retropie 3 and basically it running flawlessly I can barely get the rpi3 to work. Some days my ps3 controller will work some days it wont (bluetooth), anything I change in retroach gui never saves, rpi3 constantly freezes (cpu temp hasnt gotten higher than 149 F. The rpi3 freezes when trying to transfer roms often. Is it just me or are other having this cluster fuck of issues. I installed kodi it didnt work originally now it works. Its like theres no consistency with the functions of the system. HELP!!!! Are we still waiting on a better build or is this it?
      • herb_fargusH
        herb_fargus administrators @smoothmalik
        @smoothmalik if youd followed this post https://retropie.org.uk/forum/topic/3/read-this-first youd have already seen the 10 or so posts explaining the issue and t for the ps3 controller with onboard bluetooth and the solution to it.
          spudgunman
          get a better power supply more amp. I am running it with zero issues.
          kris964K 1 Reply Last reply Reply Quote 0
            mediamogul Global Moderator
            Never rule out an exorcism either. However, finding an old priest and a young priest that feel comfortable working together these days can be difficult.
            • kris964K
              kris964 @spudgunman
              @spudgunman said in Does Retropie 3.7 on RPI3 actually work for anyone?:
              This also solved a lot of problems for me.
              • CharcoC
                Charco
                Yes, on mine.
                • Drakaen391D
                  Drakaen391
                  What size power supply are you running?
                  It seriously sounds like a lack of power...
                  Also RetroArch/emulationstation changed in the update
                  RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
                  Retropie (Latest Stable)
                  PiBox with Wind Tunnel Cooling System
                  • O
                    opensourcefan
                    3.7 on the RPI3 works about 85% for me. I get the occasional freeze (after 4.4 Kernel Update) but for the most part it's solid.
                    RPI3, v 3.7 from SD Image, Last update, Bluetooth v1.0, Child-Friendly ES, 3 amp Power Supply, Case w/fan.
                    glennlakeG 1 Reply Last reply Reply Quote 0
                    • glennlakeG
                      glennlake @opensourcefan
                      @smoothmalik When it does start up do you see a small square in the upper right coroner? That's a sure sign of a low power. It's not so much what the power supply says on the plug, rather the actual power that is being drawn by your RPi3. A long, thin cable can pull the power down to an unusable level.
                        smoothmalik
                        5v 2.1amp power supply ....I never see the rainbow icon. Ive noticed it's been freezing when I try to access the retroach gui
                          smoothmalik
                          i tried updating the kernel not sure if it actually completed after all the loading on the screen it just stopped and I waited for like 20 mins and nothing further happened nor went back to any prompt screen. So I just unplugged it
                            mediamogul Global Moderator @smoothmalik
                            @smoothmalik said in Does Retropie 3.7 on RPI3 actually work for anyone?:
                            The Rpi3 power requirements are actually 5v 2.5 amps. It might not seem like a big uptick, but it can make all the difference and might very well put your problems to rest.
                            Edit: If you do choose to upgrade your power supply, I would also start with a fresh RetroPie install so as to ensure you start on solid footing after your previous issues.
                            • glennlakeG
                              glennlake @smoothmalik
                              @smoothmalik Are you using any USB devices? Everything you plug in requires some power and it may be just enough to make it flaky or not boot. Maybe try to boot without keyboard or mouse or controller plugged in. I know you can't use it that way but if it will boot that way it will at lease give you something to work on.
                                smoothmalik @glennlake
                                @glennlake i boot with no peripherals hooked up to it. I have two heatsinks installed aswell. I think I've narrowed down when it freezes. When trying to transfer roms from computer to rpi3 and when trying to access the retroarch gui in game. I was able to recreate both of those issues
                                • E
                                  eightbit
                                  Start fresh with a fresh install of RetroPie and try again. If you are still having these issues maybe your Pi is defective. I run RetroPie v3.7 on three Pi 3 models and everything works as expected. I do not have these oddball issues you are experiencing at all.
                                  • O
                                    opensourcefan @glennlake
                                    @glennlake said in Does Retropie 3.7 on RPI3 actually work for anyone?:
                                    No small square in the corner, I'm always on the look out for that but my power supply seems pretty good.
                                      smoothmalik @eightbit
                                      @eightbit i originally installed on a mac using Pi- baker ...ill try on a pc
                                        I used ApplePi-Baker to install originally and I also use it to make and restore from all of my backups. I would be surprised if it is causing problems. It still sounds like you're having power issues, but if you have definitively ruled out that scenario, then you probably have a defective Pi. It could have even been damaged sometime after you bought it. Was their any extended period of time when you didn't use a case? Has it always been plugged into a surge protector?
