    8bitdo fc30 pro does not work in kodi
    21 Posts 4 Posters 9.7k Views
      rt @Rascas
      @Rascas said in 8bitdo fc30 pro does not work in kodi:
      In Kodi 16, you were suposed to configure only the d-pad, so only 4 axis lines with the corresponding ids of your d-pad. Something like this:
      https://github.com/HerbFargus/kodi-joypads/blob/master/keymaps/retrolinksnes.xml
      In Kodi 17 you have to activate the Joystick Support in the peripheral addons. If after that your joystick still doesn't work, you have to report it upstream since I didn't touch the joystick support in Kodi 17.
      sorry for taking for ever to try this stuff out just been a little busy.
      in kodi 16 i have tried every single combination of axis and still was not able to get the dpad to work. i may just wait until version 16.2 as i can still navigate through the menu even though it's not ideal.
      in kodi 17, the peripheral addon for joystick was enabled but the "configuration attached controllers" is still greyed out. I guess i'll have to report it upstream.
