    iBuffalo USB Controller Works in Menus not in Games
    controller help
    3 Posts 2 Posters 748 Views
      amoreau13
      Trying to setup a new iBuffalo USB 8 button controller. Runs through the standard emulation station setup just fine. I've also successfully used JSTEST to test out the controller and it passes the test. When I get into games the start button doesn't work so you cannot start a game and cannot exit a game. When loading the game I get the little yellow message and it says the controller is not configured. I've scoured the web for answers and haven't come up with anything.
      I'm using a Raspberry Pi3 and the latest version of Retropie. I have a Logitech F310 controller that works just fine with the system. No issues at all with the start button.
      Any suggestions as to what I can try? I've tried reprogramming the controller several times using emulation station.
      rbakerR A 2 Replies Last reply Reply Quote 0
      • rbakerR
        rbaker @amoreau13
        @amoreau13 I have one and it works. You really need to say what emulators and games you are experiencing this with as per the link along the top.
          amoreau13 @amoreau13
          @amoreau13 said in iBuffalo USB Controller Works in Menus not in Games:
          Adding some info to request:
          1. Raspberry Pi 3
          2. Retropie 4.1 downloaded from Retropie web site
          3. Experiencing controller issue with stock emulators in Retropie - Sega Genesis games and NES games tested so far - select and start buttons do not work.
          4. Used JSTEST to make sure I had the button numbers correct on the controller in the config file.
          5. Controller is iBuffalo USB SNES controller
