    Genesis not showing on fash drive
    2 Posts 2 Posters 828 Views
      Cole_48
      I think I accidentally deleted the Genesis folder, and so and I can't add Genesis roms. Can I just make A new folder and name it correctly? If so what do I name it.
        BuZz administrators
        the genesis folder was just a symlink to the megadrive folder. You can't create a new genesis folder but you can recreate the link by reinstalling lr-picodrive (or any other megadrive emulator) from retropie-setup menu 5.
        Or just use the megadrive folder.
