    Vice C64 - runs very fast and no sound
    vice joystick
    7 Posts 3 Posters 2.1k Views
      DrFreeman
      Hi all,
      the vice C64 emulator worked fine. Now I wanted to save the settings for using Joysticks. And after that all games runs very very fast and no sound is enabled.
      I tried already deinstallig and rebooting and new installation. But I have the same problem. Is there still a condif file that I could delete? Or is formatting and installing the hole retropie my only chance?
      Best wishes
      Michael
        DrFreeman
        SOLVED:
        I had to delete the the files in /opt/retropie/configs/c64/
        After that I installed new and BAAAAM! :)
        • RetroFreakR
          RetroFreak
          I'm having the same problem. How do you do all these things?
          I installed vice normally from the bios and started to play boulderdash.
          Game runs on 900% speed and no sound.
          I tried adjusting the speed settings to 10% speed and still no sound and 900% speed.
          How do i delete the opt/retropie/configs thing?
          Do i delete it trough wifi on my PC or?
          Do i have to reinstall C64 again from the bios?
            tuki_cat @RetroFreak
            @retrofreak I think that Vice has a "warp" mode, this may be enabled by default. The "warp" is used to speed up loading times.
            Check the settings in gui, I can't remember where the setting is, but I'm think it is under speed settings.
            Turn this off and things should work OK.
            RetroFreakR 1 Reply Last reply Reply Quote 0
            • RetroFreakR
              RetroFreak @tuki_cat
              @tuki_cat said in Vice C64 - runs very fast and no sound:
              Well i'm sure it's not in speed settings.. I tried everything it let me do on speed settings.
              All it had was refresh rate and tape speed.
              I tried everything and it didn't affect the game at all.
              I guess i'm now in a manhunt to find that cursed "warp mode" somewhere.
                @retrofreak Hi, I have just checked and the warp mode is under speed settings, the first option at the top of the screen is "warp mode" if a "*" appears next to it , it is enabled.
                The is on the standalone version of Vice, it we be different if you are running lr-Vice.
                Do you know which one you are running?
                • RetroFreakR
                  I just opened bios from retropie and installed "vice"
                  EDIT:
                  Found it! Thanks a million!
