    Will not boot after power off
    28 Posts 10 Posters 16.1k Views
      day2k
      Hi All, can anyone help?
      After building the SD card image from windows, it boots fine and I can get in and play games ok, but when I turn it off it will no longer boot . I have rebuild the disk image and gone in again. and power off, same issue.
      Am I doing something wrong here?
        mediamogul Global Moderator
        How are you turning it off? Are you letting it fully complete it's shutdown process. Sometimes you hear of people unplugging the pi's power or running the USB power cord into something that has a power switch. These activities can cause the SD card to corrupt. Also, what model pi are you using and what type of power supply are you using it with?
          day2k @mediamogul
          @mediamogul Thanks for getting back to me, I am using a Pi 3 Model B. the first time, I did just unplug the power. but the second, I shut it down from the menu and it wasnt until abotu an hour later I tried to turn it back on again. (with no luck) so I presume this was fully shut down.
          FinheadF 1 Reply Last reply Reply Quote 0
          • FinheadF
            Finhead @day2k
            @day2k said in Will not boot after power off:
            Best way I have found to have a proper shutoff and turn on cycle is to add a switch and script. I bought one of these and couldn't be happier it works prefectly, have not had a issue at all.
              day2k
              Thanks for the link, I am not sure this will solve my problem though, as i shut down properly last time. Do you think it could be an issue with my Pi?
              • FinheadF
                Finhead @day2k
                I doubt it would be your pi. What power supply, what SD card and how are you powering it off and how are you powering it back up?
                  day2k
                  its a standard micro SD powering it, it runs fine on first boot. then I have tried using the shutdown from the menu and it turns off. I then unplugged it and plugged it back in and it wouldnt boot. lights flash on the board but nothing on the screen
                    day2k
                    sorry and it is a Kingston 16gb card
                      mediamogul Global Moderator @day2k
                      @day2k
                      Although you are now shutting it down correctly, it could be that one of the times you did not has corrupted your SD card and is still affecting the performance. Have you tried completely reinstalling since then?
                      • FinheadF
                        Finhead @day2k
                        Standard SD powering it? Not sure what you mean by that.
                        The Rpi3 needs a 2.5 amp power supply anything less can cause some wierd issues, it can cause boot issues for sure.
                        But I do agree with @mediamogul you might have a corrupt image from the inital shutdown issues.
                        • O
                          opensourcefan
                          When I upgraded the other day to fix my ps3 Bluetooth issues the update broke the shutdown option. When used it won't boot up again, if I kill it, it'll boot on the next plug in.
                          So as of right now the only option for me is to kill the power to turn it off.
                          RPI3, v 3.7 from SD Image, Last update, Bluetooth v1.0, Child-Friendly ES, 3 amp Power Supply, Case w/fan.
                            That has all the smackings of card corruption. I never suggest a full reinstall of a system like this lightly, but if you're looking to remedy the issue, it might be necessary.
                            Edit: Aaaand I just realized I'm not talking to the same person. Sorry, although with a problem like that I'd backup my data as soon as possible.
                              day2k @mediamogul
                              Yep, cleaned the card with disk part and installed totally clean image and it happened again. workerd on first boot then on shut down and then taking the power out and putting it back in it wont boot.
                              ~I will try a different card.
                                One vital piece of information you have yet to disclose is what kind of power supply you are using. If you're still seeing this behavior with a fresh install, it's most likely to blame here. What we're looking for when we ask about the power supply is what is the specified volts and amps it outputs. If you're able to discern the manufacturer of the power supply, that can sometimes be helpful too.
                                D W 2 Replies Last reply Reply Quote 0
                                  day2k @mediamogul
                                  Sorry a standard MicroUSB charger for a phone its samsung came with my s7. Not sure it is 2.5amp to be honest. will check that. Just tried a new card. same thing
                                    day2k
                                    Just installed an app on my phone to check the charger, looks like its 1 amp.
                                    will try to find another power supply
                                    • FinheadF
                                      Finhead @day2k
                                      @day2k No phone charges are not going to cut it (most are 2 amps or lower at best) with the RPi3 you need a 2.5amp power supply.
                                        @day2k
                                        A new power supply and you should be good to go.
                                          grega8233 @mediamogul
                                          @mediamogul
                                          New power supply will not fix this issue. It is a bug in the new img. Of retropie. I have same issue using the correct power supply that came with canakit. Only way to ensure the pi will reboot is to pull the plug.
                                          mediamogulM herb_fargusH 2 Replies Last reply Reply Quote 1
                                            mediamogul Global Moderator @grega8233
                                            @grega8233 said in Will not boot after power off:
                                            Which new img are you referring to? This particular issue was from about two months ago and seemed to have been somewhat isolated. Were you experiencing it then as well?
                                            Edit: I've had very good luck in ordering Canakits in the past, but as they are not affiliated with the official Raspberry Pi organization, you should never simply assume their accessories are to spec. What model Raspberry Pi are you running and what are the specifics of the power supply? Also, what all do you have plugged into the Pi when you notice this behavior?
