    Help with a menu problem
    helpmenu
    10 Posts 3 Posters 1.8k Views
    • L
      leeskinner126
      Someone please search the forum dont even know what i am looking for. Have just got a r pie 3 everything was working great just trying to figure out the buttons, brung up some menu must have hit something and now everytime i press a button brightness and volume pops up and i carnt get the menu box back up it was that quick dont even know what the menu box was
        mediamogul Global Moderator @leeskinner126
        @leeskinner126
        L 1 Reply Last reply Reply Quote 1
        • L
          leeskinner126 @mediamogul
          @mediamogul right ok read the rules now what do i do
          • TMNTturtlguyT
            TMNTturtlguy @leeskinner126
            @leeskinner126 can you please provide more information? Did you follow setup instructions? Did you first set up a keyboard? Did you set up a controller? What type of controller. What menu were you in when you caused the issue?
            • L
              leeskinner126 @TMNTturtlguy
              @TMNTturtlguy ok mate i set the key board up and have a ps4 controller in everythink was fine just going and checking the game acually worked and they did. Pressed r1 menu poped up think i check along and now the buttons bring up brightness/volume alnog the bottom of the screen and the r1 button will not bring the menu up :(
              • TMNTturtlguyT
                @leeskinner126 first off, I am not sure why your R1 would be set up to bring up a menu? Regardless, use your keyboard and press the button you set up as the start button. Choose to configure a controller and reset up your PS4 controller. See if that works.
                • L
                  @TMNTturtlguy yip reset up and prob still there
                  mediamogulM TMNTturtlguyT 2 Replies Last reply Reply Quote 0
                    @leeskinner126
                    It'll help draw in more possibilities if you can provide the information requested at https://retropie.org.uk/forum/topic/3/read-this-first
                    • TMNTturtlguyT
                      @leeskinner126 I agree with @mediamogul, it is hard to figure out what your issue is with the information you are providing. Do you know how to get into your system through either an ftp like winscp or can you get in by ssh? If you can do that, you can get to the controller input file. I don't have access to my pi right now, but i believe the location for the file is: /opt/retropie/configs/all/emulationstation/es_input.cfg
                      If you could access that, you can then see what buttons are mapped where and modify them. You could also delete that file and then reboot and reset up your keyboard and controller. I would recommend that you spend some time in the Docs section of this site as well as the information on github
                      • L
                        @TMNTturtlguy thank you will give it ago
