    issues running controlller on pifba
    pifba
    3 Posts 3 Posters 760 Views
      adamLazar
      Hello there.
      I have the latest update of retro pie and this is my first running it on a rasp raspberry pi 3. i am trying to use pifba as my NEO GEO emulator, but my ps3 controller is unrecognized by the emulator via Bluetooth although it works fine when it is plugged via USB, Using the same settings on fba2x.cfg. I believe that i have updated the emulator through retro pie-steup. is there anyone who can help? I am not sure if this problem was discussed around here before.
      Thank you.
      mediamogulM meleuM 2 Replies Last reply Reply Quote 0
        mediamogul Global Moderator @adamLazar
        @adamLazar
        We'll really need more information in order to help you. The required information can be found at https://retropie.org.uk/forum/topic/3/read-this-first
          meleu @adamLazar
          @adamLazar no development is happening on pifba.
          If you're using a raspi3 you should try lr-fba for neogeo emulation. It's a lot easier to configure, etc.
          Maybe you'll need to find the "FB Alpha 2016 Reference Set" somewhere else (we don't share ROMs/links here) to get the compatible ROMs.
