    Probleme language rom
    probleme
    5 Posts 2 Posters 1.8k Views
    • I
      ibiza7
      Bonjour,
      J ai mis plusieurs roms psp et psx version européenne et quand je lance un jeux il apparaît tout le temps en anglais. Les jeux en fr sont pas tres nombreux la plupart sont en Européen francais inclut mais reste en anglais durant le lancement.
      Jai suivis des tutos en mettant ma raspberry et clavier en francais mais quand je navigue sur retropie cela est toujours en anglais. Comment puis-je jouer au jeux en francais s il vous plais. J ai testé avec plusieurs version de retropie apres deux jours continue je ne sais plus quoi faire...
      Hello,
      I put several roms psp and psx European version and when I launch a games it appears all the time in English. The games en fr are not very many most are in European French but include in English during the launch.
      I follow the tutos by putting my raspberry and keyboard in french but when I sail on retropie it is always in English. How can I play the games in english if it pleases you. I tested with several versions of retropie after two days continuous I do not know what to do
        kbronctjr
        Hi, in this page:
        http://psxdatacenter.com/pal_list.html
        you can see all the games versions and the languages, so you need to launch the game version that has the language you want to play
        • I
          ibiza7
          Thank you :) difficult to find in french version
          • I
            ibiza7
            le numéro sles correspond bien a mon fichier qui indique une version française mais en lançant le jeux cela reste en anglais?...
            The number sles corresponds well to my file which indicates a French version but by launching the game it remains in English....
              kbronctjr @ibiza7
              @ibiza7 Then you should be able to select the language inside the game if it indicates more than one language (One example is Crash team racing, where you can select the language at the start of the game)
