    Control recognizes but does not work
    keyboard usbps3 bluetooth
    3 Posts 2 Posters 823 Views
      tuttuto
      I installed the ArcadePunks site image [Redacted]
      Everything installed, ok, but with the keyboard connected, it does not make any movement. I can not access any emulator or game. When I press "ESC" it goes to terminal mode (which means the keyboard is working). I already connected a control of the PS3, which it also recognizes as being connected but I can not touch anything, nor configure. The version is 4.2.1. And my raspberry 3 b.
      What do I have to do to reconfigure my keyboard or even the ps3 controller so they can fully work?
      AlexMurphyA 1 Reply Last reply Reply Quote -1
      • AlexMurphyA
        AlexMurphy Banned @tuttuto
        @tuttuto Third Party images pre-loaded with ROMs are not supported on this forum. You should seek support from where you downloaded it.
          tuttuto @AlexMurphy
          @AlexMurphy Thanks!
