    Weird PS1 (pcsx rearmed) control issue
    questioncontrol issueps1twisted metal 2
    10 Posts 3 Posters 2.5k Views
      ravagetalon
      Hello,
      I'm running into a weird issue with Twisted Metal 2 (PS1). Its the only PS1 rom I have that seems to not recognize my controller at all (8bitdo SFC30Pro). I have TM4 and several of the Crash games and they all work fine.
      RetroPie 4.2. on RP3, pcsx-rearmed
      edmaul69E NastyButtler322N 2 Replies Last reply Reply Quote 0
        edmaul69 @ravagetalon
        @ravagetalon go into the rgui after you start the game (select & x) go into quick menu, options and change all the controllers (all 8) to analog or change them from analog.
        NastyButtler322N 1 Reply Last reply Reply Quote 0
          ravagetalon
          Done. No dice. Same issue.
          • NastyButtler322N
            NastyButtler322 @ravagetalon
            @ravagetalon Have you tried turning analog off from the emulator menu? I had an issue with a twisted metal ROM and it seems like this was the issue. I can't remember for sure, but it seems like it had to do with the analog setting being on.
            Wazzz up
              @ravagetalon and you turned all the analogs off?
              • NastyButtler322N
                NastyButtler322 @edmaul69
                @edmaul69 said in Weird PS1 (pcsx rearmed) control issue:
                I just saw this, and then saw the poster say no dice :\ Just disregard my last comment
                Yeah, I'm confused too. Do you have to use rearmed? Rearmed works good, but the default libretro emulator hasn't let me down yet.
                Wazzz up
                  ravagetalon
                  Rearmed is the only emulator installed by default. I may try some others though.
                  @NastyButtler322 I have turned analog off for all of them as well as on. I'm continuing to experiment though. Will keep posted.
                  • NastyButtler322N
                    @ravagetalon Oh. I built retropie on top of raspbian lite instead of using the image file. That's a weird problem.
                    Wazzz up
                      edmaul69 @NastyButtler322
                      @NastyButtler322 can you post your retroarch-core-options.cfg and your psx retroarch.cfg?
                      • NastyButtler322N
                        @edmaul69 no problem. It may be a little while though. Tomorrow hopefully. I'm building a 64 bit distro for the pi 3 and also have a lot of homework.
                        Wazzz up
